Tales From the dyno: S-AFC vs. XFlash
Old Feb 23, 2005 | 07:23 PM
shiv@vishnu's Avatar
Post Tales From the dyno: S-AFC vs. XFlash
03 EVO with full exhaust (no cat), bov, mbc and intake
Custom-tuned S_afc (by another dyno tuning shop) vs. v330 XFlash (with our boost fitting-- MBC removed)
attached graphs:
whp/torque
boost/afr
Attached Thumbnails Tales From the dyno: S-AFC vs. XFlash-nguyen190.jpg   Tales From the dyno: S-AFC vs. XFlash-nguyen290.jpg
Old Feb 23, 2005 | 07:26 PM
electricevo's Avatar
[QUOTE]
02 EVO with full exhaust, bov, mbc and intake
02 Evo...is it a 7?
Old Feb 23, 2005 | 07:30 PM
doh... i mean 03. edited
shiv
Old Feb 23, 2005 | 07:33 PM
Sick numbers with just those mods, keep up the good work man
Old Feb 23, 2005 | 07:38 PM
jj_008's Avatar
Why was the SAFC run done at 15psi?
Old Feb 23, 2005 | 07:39 PM
wrong axis.. you're looking at AFR
shiv
Old Feb 23, 2005 | 07:45 PM
jj_008's Avatar
I am assuming the axis on the left is psi and the black line is the SAFC. It sure looks like the black line doesn't come close to the 21 psi line.
Old Feb 23, 2005 | 07:46 PM
Az3ar's Avatar
great improvement
Old Feb 23, 2005 | 07:48 PM
2literturbos's Avatar
Looks like my Xflash just i made 275 with a intercooler and fuel pump.
-James
Old Feb 23, 2005 | 07:56 PM
That's because it runs 20psi That's what it was tuned for by the dyno shop. Running more boost, on 91 oct without ignition control (S-AFCs rule! ) is pointless. Results in run to run inconsistency and knock retard.
Shiv
Old Feb 23, 2005 | 07:58 PM
jj_008's Avatar
Shiv
Ok, thanks for the clarification.
Old Feb 23, 2005 | 08:03 PM
Widebandphillip's Avatar
Kinda unfair since you ran more boost than the afc. About 3 psi more.
Old Feb 23, 2005 | 08:10 PM
How is using a better combination of air, fuel and timing unfair? It's not my fault the S-AFC has no ability to retard timing
Old Feb 23, 2005 | 08:12 PM
cooter's Avatar
Damn cheater....
Old Feb 23, 2005 | 08:13 PM
Kwman's Avatar
wanna trade my afc for an xflash?
