Swapping ECU's
Old Mar 23, 2005 | 04:56 AM
UncleXSO's Avatar
gvr4v. So if I am understanding this correctly, I would have to drive my car down to the dealership, swap the new ECU into the vehicle there, then have them flash the ECU to match my keys?
Old Mar 23, 2005 | 05:04 AM
Dyno4mance's Avatar
EXACTLY......this is why your car does not start with the new ECU
Old Mar 23, 2005 | 05:07 AM
UncleXSO's Avatar
Obviously I would want to do this before I sent an ECU in for XEDEFlash because when the dealer flashes the ECU it would probably wipe out the XEDEFlash, correct?
Old Mar 23, 2005 | 05:17 AM
Dyno4mance's Avatar
That is the way I would do it...although make sure the only thing the dealer does is sync the imobilizer on the key to the new ECU so it starts.....do not alow the dealer to flash in a P0300 fix (that does not work) as this may cause problems with installing the xedeflash
Old Mar 23, 2005 | 02:38 PM
UncleXSO's Avatar
Andrew thanks again. I appreciate your help today.
Old Mar 23, 2005 | 02:48 PM
Volunteer's Avatar
Your're right do not let the dealer by any means flash your ECU with the new P0300 flash for the misfire. Shiv will not be able to do anything with it. I'm working with Mitsu right now trying to get my ecu flashed back to what it was before. I never had a random misfire they just reflashed my ecu because it was an update. I drove 6+ hours for a Dyno day with Shiv in Dallas and he couldn't do anything with my ecu. As it is the with the Xede in I'm hitting the fuel cut off and have eratic idleing because of this stupid P0300 flash. Be careful if your taking your car to the dealership, they had several TSBs so I let them do them all while I was there. Now I'm trying to get it reversed and from what I'm understanding I might be **** out of luck unless the Mitsu tech line can help us out.
mosscar
Oct 23, 2015 08:55 AM
cerevo
Feb 13, 2014 05:39 AM
2012 Lancer GT
Lancer Engine Tech
May 20, 2012 05:47 AM
Cirrusly Evolvd
Mar 9, 2007 12:18 AM
