TME or 10.5cm Hotside?
Old Apr 26, 2005 | 08:46 PM
  #31
marksae's Avatar
So does the boost hit slower w/ the 10.5 cm^2 turbine housing, but give you more top end? The larger turbine housing should give you more lag.
Old Apr 27, 2005 | 11:02 AM
  #32
spoolingEVOx's Avatar
arent the housings on both 10.5cm?
if anything the TME would suggest an improvement in spool and top-end over the oem '03-'04 9.8cm housing.. right?
Old Apr 27, 2005 | 01:39 PM
  #33
Vishnu_Evo8's Avatar
i made same power at tme with my 10.5.. so except for slight lag difference it prolly is nto worth it.
Old Apr 27, 2005 | 03:03 PM
  #34
EvoSam's Avatar
I have the TME and love it. I would imagine that the install for the TME would be easier than the hotside. With the TME all you do is pull the old turbo out and put the new one in. The hotside sounds like a whole lot more labor beyond that. Do a search of the forums for my name and see some dyno results I got with it. Or, talk to Sigfrid there in Houston about my car, he knows all about it.
Sam
Old Apr 28, 2005 | 04:53 AM
  #35
Jorge T's Avatar
Actually the hotside is easier, no oil or coolant lines to deal with.
Old Apr 28, 2005 | 05:47 AM
  #36
ruzs's Avatar
hot side
I had to remove the turbo from the car to install the hot side so both mods require removing the oil lines. The only difference between the two is that you have to separate the hot side to change it vs. swapping the turbos, but the work consists of removing 1 clamp so it is difficult to say there is a difference.
My opinion is to do the hot side and a O2 housing and then wait until a bolt on turbo comes out that has substantial capabilities.
Sigfrid
Old Apr 28, 2005 | 07:33 AM
  #37
HemiBaby's Avatar
Does the TME come with 10.5 H/s standard? If it does is it the same h/s on the 05 evo?
Old Apr 28, 2005 | 07:41 AM
  #38
KLancer1997's Avatar
http://www.dyno4mance.com/store/prod...p?sku=METU1001
http://linux.forcedperformance.net/m...ode=Lancer_EVO
According to these two vendors it comes with the 10.5. As for being the same as the 05 hotside, I would assume so but I don't have any part numbers to reference off of the TME to confirm this.
Old Apr 28, 2005 | 07:51 AM
  #39
Mark T's Avatar
Is the ver.9 turbo larger than 10.5?
Old Apr 28, 2005 | 07:58 AM
  #40
http://media.mitsubishicars.com/deta...28286&mime=ASC
Looks the same.
Old Apr 28, 2005 | 08:40 AM
  #41
marksae's Avatar
Although the TME turbo and the 05 turbos have a 10.5 cm^2 hotside, the wastegate design is different between the two. The TME 10.5 hotside uses an oval shaped valve, whereas the 05s use a circular.
