TME or 10.5cm Hotside?
Old Apr 4, 2005 | 09:21 AM
Jorge T's Avatar
Is the TME extra $ worth it or is the 10.5cm hotside just as good?
Old Apr 4, 2005 | 09:29 AM
4-BNGR's Avatar
The price diff substantiates not having to pay for labor, etc. unless you will DIY
Old Apr 4, 2005 | 09:30 AM
jman425's Avatar
the titanium turbine shaft is lighter, resulting in a faster spool-up, which more than compensates for the increased lag caused by the bigger 10.5 housing .
Old Apr 4, 2005 | 09:51 AM
4-BNGR's Avatar
Buddy of mine has a '05 GSR where I have an '03. No increased lag IMO - whatsoever... And his topend is better b/c he flows better...
Evo_doer's Avatar
Any valid testing #s before the gums start chattering?
Old Apr 4, 2005 | 09:53 AM
jfh's Avatar
jfh
'05 models also have a different compressor housing.
Old Apr 4, 2005 | 10:13 AM
gsujeff55's Avatar
imo the hotside is the way to go. you will cut out most of the labor cost if you can pull the turbo yourself and send it to Andrew to put the hotside on.
i think he charges 1 hour labor to put the hotside on. Plus he sells them cheaper than anywhere else.
Old Apr 4, 2005 | 10:17 AM
lowkey's Avatar
Registered User
I’m with you. Seems a lot of people make claims because they have read it somewhere. As far as I know Buschur is the only that have tested both the MR and TME housings. He saw no substantial difference.
https://www.evolutionm.net/forums/showpost.php?p=1825027&postcount=610
Old Apr 4, 2005 | 11:49 AM
Jorge T's Avatar
How much spoolup will the 10.5 sacrifice?
Install labor is not an issue since I have access to a shop.
Old Apr 4, 2005 | 11:51 AM
Jorge T's Avatar
I also have 264/272, did you feel any lag from the 10.5?
Old Apr 4, 2005 | 12:12 PM
shiv@vishnu's Avatar
FWIW, I've consistently gotten better results with cars that had the TME turbo. The Ti internals do spool up faster and offer less drag, IMHO. They seem to both have a slightly better response as well as max power numbers. The difference isn't big but it is there for sure.
Shiv
Old Apr 4, 2005 | 12:20 PM
gsujeff55's Avatar
no not really, not anything i could feel. But i cuold feel the extra power.
Old Apr 4, 2005 | 12:21 PM
Jorge T's Avatar
Shiv, thanks for the reply! I'll wait for the TMEs to be in stock again.
Old Apr 4, 2005 | 01:42 PM
jfh's Avatar
jfh
If you can pull the turbo yourself, you can also change the hotside. It's a simple bolt-on.
Old Apr 4, 2005 | 03:30 PM
bdking57's Avatar
How much is the TME install... this has been the path i wanted to take for awhile.
