Any maps for Cyl. Head job & 280 cams?
Originally Posted by Ludikraut
It's my understanding that as far as the connections go, it's a standard Garret GT turbo, no? So any kit that can accomodate a Garret reverse scroll turbo should work, I'd think.
l8r)
l8r)
you'd have to find
1) someone who already has a turbo kit
2) that wants to upgrade or downgrade to the 3071
3) that can find someone who will buy their turbo
4) and has a kit that has a downpipe that will fit
5) and an intake pipe that will fit
-- number 3 almost hurts the brain. its infinately regressive unless you are lucky enough to find someone to swap with you.
Originally Posted by smokedmustang
Would like to know if any maps exist for polish/port head with larger springs, as well as 280 HKS cams. Please help. Should I wait to do this until maps are avail? Have all upgrades but stock turbo.
In this case, my guess is the most significant factor here is the HKS 280 cam set as opposed to a ported head. In other words, if I had to choose between two maps, one from a car with 272s and a ported head vs. one from a car with 280s and a stock head, I'd be willing to hedge a bet that the map from the car with the 280s will be a closer fit, simply because what I've seen indicates the cams have a far greater effect on dynamics that potential affect fuel mixture than ported heads.
Just my opinion.
Originally Posted by Ted B
The EVO head already flows well enough to give very solid Ve potential, and I have yet to see anything that proves porting the EVO head is beneficial by a significant margin in a *real world* setting. The better the initial Ve, the less there is to be gained by porting the head.
If low speed response was lost after installing a ported head, it is because port velocity was reduced as a result.
Porting the head affects volumetric efficiency (for better or worse). Ve is relatively unchanged regardless whether a smaller or larger turbo is used because the difference between the two is the pressure and temperature of the air charge, whereas the volume of the air charge remains relatively unchanged.
The HKS 280 cams are no harder on the stock springs than the other HKS cam sets, so no, you don't need stiffer springs.
The 280 cams deliver more power potential than the others, but as always, you sacrifice something (idle quality and low speed power) to gain something else.
There is no definitely answer to that question because what gains can be made depend on supporting mods and competent tuning, and I would not even consider the HKS 280s without a sufficient dose of either.
Originally Posted by rlazer5000
Anyone know of a place where they have an AWD dyno in IL?
Also, 780 cc injectors seem to be a bit of overkill for just a 3071R. Wouldn't 660's match up better?
The meth injection works especially well with the Xede because since the Xede contains two maps that can be switched on the fly, it allows you to continue running with the 93 oct map should you deplete the methano reservoir. With other systems, if you run out of methanol, you have to keep your foot out of it until you get a refill.
My cam timing is not set to give max hp, but rather best midrange torque. On a Dyno Dynamics dyno, this is 348whp and 340ft lbs, which works out to something like 400whp and 390ft lbs on a Dynojet. This is attained running a fairly reasonable 25psi at the torque peak, and tapering to only 20psi at peak hp.
I am using the 16G with larger hotside and Ti wheel at the present, but I'm upgrading to a GT35R soon (already have it).
Somone else has already claimed dibs on my turbo, so we'll see what happens with that.
I do not believe Vishnu is selling the methanol kits yet. Mine is a kit from SMC Enterprises, which you can get either directly or through Buschur (no price difference).
Originally Posted by mhgsx
There are 2 Mustang AWD dynos in the area, Performance Autowerks in Naperville and Fall-line Motorsports in Northbrook.
l8r)
Ok,
I finally figured out the signature thing, here are my mods, how much gain with the 280's? enough to mess with? I run on the gas I was dynoed on 110 LEADED. would like to re-dyno on 109 unleaded MS 109 from VP and 280's. worth it?
