Help with boost issue
Old Jul 14, 2005 | 01:10 AM
RREvo's Avatar
Hi I still have a problem with my car ever since I install ma camshafts an cam gears I can not run anything higher than like 1.28bar ( 18.5psi) at 4000 rpm it hits like 1.58bar (22.9psi) before 4000 rpm but at the 4000 rpm it drops to 18.5 psi and slowly goose to like 19 psi anybody have any suggestions what to do I tried to adjust the boost table in the XEDE but noting works
Old Jul 14, 2005 | 04:26 AM
smokedmustang's Avatar
you need a dyno tune to smooth out the boost-map/spike I believe,barring the fact you have no boost leaks. my 2c
Old Jul 14, 2005 | 05:19 AM
dude's Avatar
Check your cam gears to make sure they aren't off one tooth.
Old Jul 14, 2005 | 05:38 AM
kmcconn9's Avatar
I agree that you are going to need a tune, you might have a boost leak as well..
Old Jul 14, 2005 | 10:36 AM
RREvo's Avatar
Ok how can I due that what should I be looking for ?
Old Jul 14, 2005 | 10:52 AM
shiv@vishnu's Avatar
When you zero out the boost table in the XEDE, does the boost drop to 12-13psi?
shiv
Old Jul 14, 2005 | 11:28 AM
RREvo's Avatar
shiv
Yes it dropped to 11.5psi .
Old Jul 14, 2005 | 12:14 PM
What is it at 100%? And did you remove the pill in the boost line (near the boost control solenoid)?
Shiv
Old Jul 14, 2005 | 12:53 PM
RREvo's Avatar
Shiv
At 100% is like 22.9psi and yes I remove the pill and have a XEDEFlash .
Old Jul 14, 2005 | 08:20 PM
RREvo's Avatar
bump
Old Jul 16, 2005 | 01:30 AM
RREvo's Avatar
Hi I think my problem is that I am hitting like 23psi but cant hold it because of my stock DV could that be a problem because like I said I can hit 23psi but then drops it to like 17-18 psi and then slowly climes up to 19ish psi .
