New v3 SMART firmware/software/map template here:
Old Aug 2, 2005 | 08:42 PM
  #31
gsujeff55's Avatar
well sweet, here ya go.
also, can you tell me more info about step 9 in the instructions? the file in the secret folder that you refer to in step 9 comes up with tons of numbers when i click on it. im confused there
Old Aug 2, 2005 | 08:50 PM
  #32
shiv@vishnu's Avatar
Here's your launch control enabled map. Just make sure you wire up the clutch switch as per the directions. The launch/NLS limit is set to 6500rpm, btw. This worked out the best for us.
Not sure what your question is. What numbers are you talking about?
Shiv
Old Aug 2, 2005 | 08:53 PM
  #33
gsujeff55's Avatar
http://www.vishnutuning.com/secret/
on that link, there is the xupdate code thing(xcode v3203). when i click on it, i get a bunch of numbers...thats it. In step 9 of the instructions it mentions using this for something to do with xupdate....but i don't understand what.
thanks
Old Aug 2, 2005 | 08:58 PM
  #34
thanks
Ah, i see. You aren't supposed to open the firmware file. All it has is a bunch of code in it. Instead, just select the file in XUpdate, as per the instructions, when you update your firmware.
Shiv
Old Aug 2, 2005 | 09:00 PM
  #35
gsujeff55's Avatar
but, when i copied the file from that online directory....its all funked up. I haven't selected in xupdate though....
if i update without using xupdate, will i need it?
thanks again for your time....its much appreciated
Old Aug 2, 2005 | 09:22 PM
  #36
gsujeff55's Avatar
also, shiv, if i want the launch control to be at 6k, do i just fill in the table just like you have it, but over to 6k instead of 6400?
Old Aug 2, 2005 | 09:40 PM
  #37
Sackett's Avatar
I just recieved my xede and smart today, so i'm trying to put together the entire install procedure..
your site only shows 03-04 basemaps, i assume these are close enough to use on the 05? will smart basemaps be out anytime soon?
do i do anything with this two-conductor red wire that comes off of the ECU connector, outside of the xede wiring harness? i dont see reference to it anywhere...
i was in the second batch of smart kits, got it today, but did not include the extra wire terminated for launch control.
ok i think that will get me started, thanks for the help!!
Old Aug 2, 2005 | 09:53 PM
  #38
KillaSweep's Avatar
yeah that file just displays as code if you just trying to open it. Use it through Xupdate or the update firmare option in xmap and it will load new firmware into your xede.....its easy
Old Aug 2, 2005 | 09:59 PM
  #39
USP45's Avatar
I have the smart stuff installed, and for the most part it seems to be working correctly exept I do not have an RMP pickup any more. The A/F and knock seem to be picking up (although on a mild run up to 6000 in second I did not see more the 21% on the knock table and it reads 14-15% at idel?) but I have no RPM reading. Also I tried to do a data log and I got an error saying that the comm port 1 was already in use, I am using a usb0serial adapter off of comm port 8 and it picks up and sends/recieves the Xede. Would no RPM cause the data logging not to work and what wire picks up RPM? I wrote in another thread that my black connector does not have the orange piece in it, but the pins looked to have lined up correctly when I plugged it back in.
Old Aug 2, 2005 | 10:03 PM
  #40
Sackett's Avatar
Originally Posted by Sackett
I am installing the XEDE and SMART for the first time, and on the online xede install instructions, it shows how to connect the passive boost solenoid emulator under the hood on the 05s. is this still necessary? this did not come in my kit.. HELP!!
and what about the brass restrictor pill?
Old Aug 2, 2005 | 10:44 PM
  #41
Sackett's Avatar
It appears the new load points are designed to give you more granular control of when the boost solenoid is shut off durring low load situations. I zero'd out 18 and below on my map, perhaps Shiv can give a definitive answer?
Originally Posted by KillaSweep
i have started copying my number off my screen shot to the zeroed out tables,but noticed that the axis numbers for load do not coordinate with the one from the screen shot....problems? This was in the Smart Boost table? Do we just zero out everything under 30? Like we did for the previous normal version
Also could someone point me in the right direction for the launch controls? I am not seeing it anywhere....i;m also not hooked up to my car
Old Aug 2, 2005 | 10:48 PM
  #42
That is correct. At idle, you'll now see a higher load value. This gives us a bit more resolution at low loads. Go ahead and zero out the map below 20. 20 is last seasons 8 (dumb joke)
Shiv
Old Aug 2, 2005 | 11:13 PM
  #43
Sackett's Avatar
hey shiv, how about a quick rundown on how to use the datalogging features?
mostly looking for a key of the logged variables, as well as how to log what the SMART system is doing to fine-tune basemaps.
Old Aug 3, 2005 | 05:16 AM
  #44
gsujeff55's Avatar
shouldn't us "non-smart" guys be able to log everything except AFR?
Old Aug 3, 2005 | 05:18 AM
  #45
gsujeff55's Avatar
anything on this?
Thanks
