New v3 SMART firmware/software/map template here:
So I was following the launch control installation instructions and got up to the point of attaching the clutch wire to PIN 1 of the black connector in the Xede. Guess what!! There's already a wire in there!! It's a blue one with a white stripe on it.. According to the wiring diagram in XMAP this is for boost in from the ECU.
Where should I put this wire and how do I add launch control?
Thanks
Thanks
The red wire on the xede that you strip back and tie in the other wire to install firmware, what should the voltage read on my meter. I am unable to connect to the xede and it looks like the red wire should be at 12volts and I get a .5 volt with the ignition on. I might have shorted the red wire, so I looked at all the fuses 4 times everything is ok. Now if I start my car it runs, but no lights on exed. Please help!!!!!!
Any ideas ?
Any ideas ?
Man now it's my turn for the firmware loading prob
. Is there any delay allowance for the software to upload. Seems to not even get a chance to load before I get the failured load crap and sends me to the help file. I going to try to load it manually copy/paste using the files on the C drive. Will that work also ?? Ended up using a different computer to load the firmware.
Vishnu,
Your website is not opening at all, are you guys working on it right now? I tried going there for the last 30 minutes and from two different computers in my house, no luck, could you send me a direct link?
Thanks!!
Thanks!!
Originally Posted by luscious
How about that nice copy & paste feature that was being worked on so we don't have to manually go thru & update all the entries...what happened to that?
umm i don't have my laptop in front of me, but im 99% sure copy and paste has been in the last release or two of XMap... I've used it...
Originally Posted by jj_008
Copy and paste is available in V3.2
.Thread
shiv@vishnu
43
Mar 21, 2006 10:40 AM
shiv@vishnu
213
Aug 5, 2005 03:05 PM
