xede and emissions testing
Old Aug 9, 2005 | 03:05 PM
sandm's Avatar
We are "fortunate" enough here in idaho to have emissions testing in the county that I live in. the test for the evo is to plug the machine into the obdII port and check for trouble codes and that some log has been collecting data. had quite a discussion with the supervisor on the phone today and told him that I am trying to add a piggyback computer and will they test with the sniffer. no way..
I have to have access to the obdII port and all the factory sensors. will xede/smart allow him to plug into the obdII port and see the factory computer?
if not, can I unhook it for the 5 minutes of the test, then reinstall? I have read in the forum on a obdII card reader mounted in the obd port and that the system throws p0300 codes. any thoughts?
he also stated that they will know if the ecu has been tampered with, but last year when I had it tested, I had my flash installed, running a little rich and they had not a clue, but if they are unable to use the obd port, I see flags going up....
thoughts?
Old Aug 9, 2005 | 03:08 PM
snoop's Avatar
thoughts?
Passed smog in SOCAL with a stage 1 and XEDE
This has been discussed several times you should try the search
Old Aug 9, 2005 | 03:35 PM
donour's Avatar
The thing is (unless you've gone catless or something), you _haven't_ tampered with emissions. The OBD-II port is still talking directly the the stock ECU, and the ecu is still sending it perfectly valid data.
OBD-II cars take "freeze frames" of sensor data when certain error codes appear. Those might be the logs that people were talking about.
d
berkel
Northeast Region
148
Aug 11, 2016 09:20 AM
sabastian458
43
Nov 2, 2015 01:35 PM
sdk1m
Aug 27, 2014 11:35 AM
Darewood
Dec 19, 2013 06:27 PM
daveski
Dec 18, 2013 08:46 PM
