Need Help!!! Misfiring like Crazy!!!
Old Dec 18, 2005 | 12:18 AM
IE Evo's Avatar
Originally Posted by Vroompsh
dude 30K on stock plugs, damn...and get the right plugs, the aforementioned plugs aren't the right ones. Get BPR7EIX's, theyre iridiums, slightly more money but worth it. If you cant find them at an auto shop, try motorcycle shops. Many bikes use iridium plugs as well. I could have ordered my plugs thru the shop i worked at
I used the BP8s myself gapped at 24-25ish. Regardless, try changin plugs and gap them to 25-26 and see if that helps.
Old Dec 18, 2005 | 12:29 AM
shiv@vishnu's Avatar
Originally Posted by quiksilverevo26
Hey Shiv, and everyone at Vishnu recently my car started to bog...misfire like crazy!!! When I accelerate the car starts bogging or badly suttering and then around 4-5k rpms then it will go. So I can't punch or anything. What you think it might be? I had the blitz BOV when you tuned it then I got rid of it and put the stocker back on. When doing that it felt like it lost power because I guess you tuned it for VTA. Now recently I put a Greddy RS BOV recirculating. When I put that on I felt it holding boost more thus having more power again. But now it's acting up...So does anyone know what might it be? You think I need to retune it? All you help will be appreciated.
Hard to say what it is. Any chance you could come by and let us check it out. Just call for an appointment. We'll be closed Mon and Tues but will be back on Wed
Shiv
Old Dec 18, 2005 | 08:38 AM
dude's Avatar
Originally Posted by 4GEvo63
i had the same prob after i installed my blitz intake (only mod btw)...i got rid of the problem by resetting the ecu by unpluggin the neg battery terminal...only problem is that my revs are ~500 rpms lower...ex. 80 mph at 3500 rpms, somtimes at ~3100 - 3500 rpms..
Are you saying that by resetting your ECU, your RPM @ 80mph in fifth gear changed by 500 rpm afterwards? Unless a genie magically changed your gear ratios at the same time I'm not seeing that happen. Or are you saying your misfiring problem moved 500 rpm lower in the midrange?
Old Dec 19, 2005 | 12:32 AM
quiksilverevo26's Avatar
Shiv
I'll give you guys a call to set an appt. Not driving car right now. Probably monday or tuesday I'll pull the spark plugs to see what's going on there. But definitely I'll call you guys up to set something up. Thanks
Old Jan 13, 2006 | 12:59 PM
Okay sorry for the long delay. Here's an update. I finally changed out my plugs. Went with NGK's BPR7ES. Put them in this morning started it up...looked fine...drove it felt fine...punched it....same thing. At WOT around 5k rpms it feels like fuel cut. So now Im confused. I looked around if I have any boost leaks...none. The only thing is the vacum hose that connects to the greddy type rs bov is not tight. clamps are there but youi could still slide it off. Could that be the problem? I'll Change out the hose tonight with the one supplied with the bov. And I'll update... but would that really affect anything??? Any other ideas would be appreciated...THANKS!!!
Old Jan 13, 2006 | 01:08 PM
smokedmustang's Avatar
Go check the "clunking from my glovebox thread", see if that is your problem! Good luck (My thread)
Had the problem for 1+ year, and I explained over there, why changing the plugs made it better for "a little while"
Old Jan 13, 2006 | 03:46 PM
DID you read the post? try what I did. I HAVE HAD THE SAME PROBLEM!!!!! for well over a year. now I have NO problems (500 hard test miles so far) for the love of god, read the thread, if it helps, GREAT, if it doesnt, at least you tried the cheapest way first. good luck!
Old Jan 13, 2006 | 10:12 PM
Okay I looked at the bolts...everything looked good and tight. And the problem occured before I even touched the plugs. Any other suggestions? Or do you think that the 'wires' are bad...if so I could bring it back to mitsu and have them replace the wires with warranty
Old Jan 13, 2006 | 10:26 PM
mitsuorder's Avatar
I would definitely recommend replacing the wires as they have been the culprate in similar situations for me.
Old Jan 14, 2006 | 02:44 AM
Ok quiksilver, in the initial post you said your problem is "before" 4500rpm, and over 4500RPM, the problem disappears. and now it looks like the problem is at 5K. Correct? or did I mis-read again? I would have an evo-friend come over, and swap the plug wires to see if that is the problem. I think today or this weekend, we will have your problem figured out! If you could, elaborate on your problem a bit more, when first noticed, how often it does it, have you added any new parts since the problem started, do you have any other problems you noticed first etc...I will be in and out of this site all day, and I will watch for updates.
Old Jan 14, 2006 | 02:00 PM
05-EVO-GSR's Avatar
I now have the same problem with my car. I started getting the hiccups, burbs, misfires, etc. It has gotten worse. I replace the plugs to rule out the problem. That was not it. I now suspect that the coil packs are going out. I will swap in a known good set of coils and report later.
Old Jan 14, 2006 | 03:01 PM
Have you tightened the coil bolts? are they stripped? can you take them off (bolts) with your fingers?
Old Jan 14, 2006 | 07:16 PM
mitsuorder's Avatar
really and truly try a new set of plug wires too or swap with a friend.
Old Jan 14, 2006 | 07:31 PM
dbdude's Avatar
I had major bogging problems and it was a major boost leak the whole time.
Old Jan 14, 2006 | 10:27 PM
jj_008's Avatar
My car just started misfiring today. Any load over 4500RPM and it feels like I am hitting a rev limiter. I will be swaping my plugs tomorrow to see if this helps.
In nuetral it will rev clean to redline.
