Boost Compensation - Possible Implementation
Old Jan 13, 2006 | 06:18 PM
  #31
Cloud's Avatar
That's amazing, keep up the good work.
I'm excited to see this development unfold.
Old Jan 15, 2006 | 06:21 PM
  #32
freedom's Avatar
Attached is a screen shot of a NLS/LC map supporting vehicle speed dependent no lift shift / launch control. The map's configuration (load/y-axis, input, output) are identical to the standard Vishnu configuration. The difference is that PWM0 is now a function of vehicle speed over a y-axis range of 0% to 95%. When the clutch is engaged, PWM0 is equal to 100%. Note that I set the launch RPM at a low number for casual testing.
I also attached the maps that I had running on the car tonight. I ran out of time so no pictures.
Attached Thumbnails Boost Compensation - Possible Implementation-nls_lc_map.jpg
File Type: zip
Old Jan 15, 2006 | 06:32 PM
  #33
shiv@vishnu's Avatar
That's fantastic!
Old Jan 16, 2006 | 07:35 PM
  #34
freedom's Avatar
Here is some video of a launch and a first gear shift, demonstrating speed dependent rev limits.
Sorry for the quality (compression) of the video, as well as the fact I had to split it into two files. I also dropped a little of the run up in first gear to save space. There is a 100KB limit per file...
File Type: zip
File Type: zip
Old Jan 16, 2006 | 08:52 PM
  #35
Ludikraut's Avatar
Very nice NLS video. My twin metallic clutch is soo easy to bog. I'm gonna have to set this up soon.
l8r)
Old Jan 17, 2006 | 10:51 AM
  #36
Erik@MIL.SPEC's Avatar
Hey Shiv, what are the possibilities of incorporating this into the XEDE on your end?
Old Jan 17, 2006 | 06:02 PM
  #37
gsujeff55's Avatar
nice work freedom....
BUT, all this technical talk confuses the **** outa me...so you gonna have to break down what i need to do in order to get speed dependant launch control into retard terms.
i want no part of NLS, just launch control....therefore 3mph i want that crap shut off.....0-2.9mph rev limit of 5500
that possible?
Old Jan 17, 2006 | 07:20 PM
  #38
freedom's Avatar
In that case the region above the lowest row would be set to zero. In simple terms rows represent the vehicle speed, thus 0 is stopped and 90 is really moving.
See attached for an example...
that possible?
Attached Thumbnails Boost Compensation - Possible Implementation-picture1.jpg
Old Jan 18, 2006 | 06:10 AM
  #39
gsujeff55's Avatar
i don't just mean the map....i mean hardware and wiring.
what do i have to do?
Old Jan 18, 2006 | 06:14 AM
  #40
gsujeff55's Avatar
also, if it works like that we could actually have speed dependent fuel management, right? i mean, if you pull any fuel out at any rate of speed other than 0 you are pulling extra fuel out while you are driving....wouldn't want that, would ya?
Old Jan 18, 2006 | 03:45 PM
  #41
freedom's Avatar
If you read above, when the clutch is not pushed the module forces a 100% (y-axis) condition, where the 100% row is equal by definition to 0 or no fuel removed.
And to answer your other question, if only two people want this stuff then it most likely will never be made available.
Old Jan 18, 2006 | 11:52 PM
  #42
Freedom-- Just PM'd you
Old Jan 19, 2006 | 04:28 AM
  #43
SuperHatch's Avatar
I can tell you this much... if you had a location in your profile, I'd be knocking on your door for the temp compensating boost control....
Old Jan 19, 2006 | 06:40 AM
  #44
Ludikraut's Avatar
I can imagine it already: the XEDE SMART system with the FREEDOM module.
l8r)
Old Jan 19, 2006 | 07:10 AM
  #45
Smogrunner's Avatar
This thread rocks. I've been using a MBC for a while which makes temp based boost settings easy, but very "Neanderthalian" LOL. When it is cold out, I pop the hood and back the MBC off a 1/4 turn. Etc.
Hey, it is this kinda thread that must drive these guys crazy: https://www.evolutionm.net/forums/sh...d.php?t=158051
