I hear a "clunking" from my glove box!!!???
Originally Posted by Eclipse2Lancer
Glad you got it fixed.....I stopped by, but you were out on a test run.
Smoked!! Great to hear about the problem being solved . . . . . . how about not trying to strip those holes any more?? hehehehe
Now . . . . . . my question to you is ---> Is the Alky turned on yet??
I will mess with it during the week! stop by sometimes!
maybe I will. I leave for Miami on Thursday but maybe early this week.
Are you going back down to the southside to get your jug of meth refilled?
I didn't know you where having this problem for so long . . . .sucks!!
I will be comming down to get my splitter back from repair soon. (trailer loading injury
) I will call you. Take care,Kevin
Originally Posted by smokedmustang
I should just wear a "muscle-shirt" and look tough, and leave the torquing to someone else. The Methanol is next on the list, now that I got over that misfire problem, which I was chasing for over a Year! When I went to Putnam Park, every time I got to the straitaway, the pop-pop at 19psi held me back! I cut the wires to the meth kit, AND THEN some, which caused me to flood out the Methanol on the ground. so my tank is now empty! (unplugged and turned off of course!)
Awesome the misfire is finally gone!
just a small tip for ya, make 2 ( 8 gauge) ground wires, one for each coil, use open end wire ends on the coil side, and run them to a tranny bolt.. its serves as a better ground point for the coils, and using and opened end one the coils, you can give the wires a little tug every time you check the oil.. better than pulling the cover to check the bolts... it cost me a whopping 2 dolllars to make them.. and 20 mins..
Thanks again.
Man I had this same problem. I ended up going back to stock wires, for better connection to the plugs and using Time-serts to repair my stripped out coil bolt holes in the valve cover. For those who have experience the pain you can have with using helicoils I REALLY recommend Time-serts, they are my hero
Dude the magnesium is like butter when it gets warm
