STI vs EVO IX
Old Feb 9, 2006 | 10:58 AM
  #31
boomn29's Avatar
Got this PM from Shiv:
Originally Posted by PM from Shiv
Stock for stock, the IX dyno's at 230-235whp. STi at 215-220whp. With a full exhaust and custom tuning, the IX will do 270-275whp. The STi will do 255-265whp. EVO holds more power up top towards redline while the STi makes peak power at around 5800rpm and falls off from there. The STi, however, makes a nice wad of torque in the 3500-4000rpm range. The EVO is excellent down low as well just not quite as strong. Feel free to post this wherever you want
Regards,
shiv
Old Feb 9, 2006 | 07:26 PM
  #32
IE Evo's Avatar
Originally Posted by Inn-Tune
The things is, while the Evo guys are upgrading their cams, valvetrain and exhaust manifolds, STi's are making 500-650 whp on stock cams, valvetrain, and manifolds. There are several STi guys doing that with forged pistons and no other engine mods, while Evos replace pistons, rods, head studs, cams, valvetrain, etc. I think once you upgrade the turbo on both cars, but before you pass 600 HP or so, the STi can be cheaper to build.
Above that level of power the Subaru engines have trouble breathing due to head flow regardless of cams, and the Evo has a definite advantage at that point in terms of power potential per dollar. Extensive head work is expensive.
The way I see it you really can't lose either way. I recommend driving both as most people decide they know which one they like best after test driving them.
Where are all these 500-650 whp STis on stockish internals? Getting there engines rebuilt after one full wot pass!
Old Feb 9, 2006 | 07:31 PM
  #33
IE Evo's Avatar
Boom weren't u a WORKs customer with your 03? U will see more power from your current Evo vs. your Sti if u choose the right tuner this time around. I was a WORK's Evo owner but went Vishnu and was very happy I did. No Sti beat me with my Vishnu stage 1+. Not even turbo upgraded ones in my area. With my p2 equiped Evo it was a drivers race with stock Stis.
Old Feb 9, 2006 | 07:42 PM
  #34
Noize's Avatar
EvoM Administrator
I had a WRX before this car and the only time I miss it is when I need to take our dog to the vet. I have friends with very modded STis, but there is no comparison in my book. I like Subaru as a company better, but from a performance and power producing standpoint, the STi falls short in so many places.
Old Feb 9, 2006 | 07:52 PM
  #35
34Turbo's Avatar
I owned both... My 05 Sti had full tbe (no cat) and was protuned at Agile Motorsports. Put down 300awhp and 310awtq on their dynopack. I would go head to head with my friends 05 evo with just a tbe intake and mbc set to 20psi with no tuning on his part.
My current evo only has a tbe intake and hallman mbc set to 20psi. I just had 4th and 5th gear pulls with the same friend. His evo is now cammed (272s) with a custom tune from TT (340awhp on their dynojet) and I beat him in both pulls. The only time he beat me was on the 3rd gear pull... That comes to show you some real world conditions...
Plus the evo handles a thousand time better... take my word for it...
Old Feb 9, 2006 | 08:29 PM
  #36
FresnoEVO's Avatar
if the warranty is important go with the sti, if not, the evo
Old Feb 9, 2006 | 09:07 PM
  #37
metzpl's Avatar
Old Feb 9, 2006 | 09:13 PM
  #38
r2kbug's Avatar
if i could do it over, i'd go sti but then again if i did, i'm pretty sure i'd be saying the same thing on a sti forum.
Old Feb 9, 2006 | 10:20 PM
  #39
rlevo's Avatar
I got the same dilema before. It's really a matter of preference. Both evo and sti are great cars. Interview tuners who tweak both cars and see which is better in their opinion. It helps minimize that confusion. After I did that, I am very happy with what I end up getting.
Good luck
Old Feb 9, 2006 | 10:22 PM
  #40
IE Evo's Avatar
Your IX has less lag and more tq is that ur point? A Yugo would beat my 30R on a non boost brake 4th or 5th gear pull at low rpms.
Old Feb 9, 2006 | 10:25 PM
  #41
Maximum Boost's Avatar
Originally Posted by Vishnu_Evo8
if you want to go fast without paying alot go with the evo.. stock sti blocks cant hold as much boost as the 4g63. thats why there is no stage 3 for the sti. The most you can get out of an sti SAFELY is arround 500 hp.
+1
Old Feb 9, 2006 | 10:26 PM
  #42
SP00LIN's Avatar
I had a very open mind while trying to choose. It came down to comfort and practicality for me. I fit in the Evo. I don't fit in the STI. Plus the back seats in an Evo will fit adults. There is NO WAY you are getting two full sized adults into the back of the STI. No way... none!
If you want torque, get a IX and put a 2.3 stroker in it. You will have a BEAST!
Old Feb 10, 2006 | 11:02 PM
  #43
boomn29's Avatar
Yep, I went the flash route with my 03. I was one of the first Evo owners, purchased in April 2003. Works was the first tuner to come out with this 'flash' idea that I'd never heard of. No offense against them per-say; but I'll never do a flash of anykind again.
Did a tuned Utec (with map selector) in my STi and loved the options a piggy-back gives.
If I can sell my current right outright; I'll probably find a used 05 STi. If not, I think I'm gonna snag a IX soon on trade-in at my old dealer. Kinda trying to see the comparisons and all. I know the Xede isn't officially out for the IX, so I'm curious what I'd put on it for a piggy-back. Of course, it'd take a month to burn through the brake-in miles...
Old Feb 11, 2006 | 03:06 AM
  #44
Vishnu_Evo8's Avatar
Evo 9s make 295 whp with full exhaust and flash on 91. In the post by boomn it said a tuned 9 only makes 275 whp. Shiv may have made a mistake when he typed that.
Old Feb 11, 2006 | 01:22 PM
  #45
boomn29's Avatar
I think what he said is correct. There's different dyno's and all that. He quoted numbers he sees on his dyno.
What I'm curious about is whether either have a bigger gain going from 91 to 93 octane? I would assume no, but curious since I live in the land of 93 and that's what my next car will be tuned for...
