Guess what this is?
Originally Posted by Evo_Kid
Its great how you like posting about this Xflasher, but wont give us a real ETA for the EVO IX Xede harness.
Shiv
Originally Posted by shiv@vishnu
Yep, it has a USB on the other end.
l8r)
Getting all the MIVEC control logic incorporated in the XEDE without a complete re-engineer isn't an easy task. It is not a simple 3D PWM output like boost control. The factory MIVEC system uses a closed loop, self-regulating logic that adjusts oil pressure based upon RPM, load AND cam position. This is the technical challenge we are dealing with in regards to the EVO 9 Xede. Fuel, timing and boost control is the simple part. That stuff took 5 minutes with the help of a ecu pinout diagram. So unless you think that programmable MIVEC control isn't important or want to build a stand-alone supplementary PID control box, give us the time we need. Okay?
Shiv
Shiv
If its gonna be a long time (2 or more months) then just say so, so I can sell the Xede and get a flash or something else.
I understand that there may be complications and thats to be expected, but I'm not askin you to have it done by next week, I'm just askin for a ETA. Thats all.
-shiv
Originally Posted by cfdfireman1
So tell tell us what can it do that my laptop can't. Please!!
-shiv
We don't have an ETA for MIVEC control. Fuel, spark and boost work right now. As does a plug-in harness.
-shiv
-shiv
Or would you like to get everything (boost, fuel, spark, mivec) working before you release the harness and update?
OMG another post
Oh boy I hope it comes out soon. I have a question though, with the XFlasher will we need to modify the vacume hoses (ie pull out the pill) or is it true plug and play? consider me pre- preodered
what it does
Um, it allows you to reflash your ecu without a laptop hooked up. You save flashes on it and then plug it into the OBD and whalla! (sp?) 100 octane map loaded, whalla! 91 octane map loaded.
And even if i did not know what it was i would want one, because it is so sexah!
Thanks for all your hardwork with the Evo's Shiv. Its nice to see Engineering types working with our vehicles that understand the whole car. Looking forward to seeing the final product!
yes
I wish I had a laptop or a least knew somebody that had one.
