Guess what this is?
Shiv,
If you do release this, please make sure you make MAPs that are SCCA legal (especially STU legal), just as Cobb has for the WRX and STi. Meaning AFR and timing can be changed but no change to boost. It would be nice to see you guys actually support various levels of motorsport for a change ... Oh yeah and please keep the price low
Originally Posted by EVOeight
Make sure I have this right: You do NOT have to leave the unit plugged into the OBDII port all the time correct?
This is a rough guess on how the process will be......
plug in some connector on the plug next to the OBDII port. This puts the ECU in "test mode" or something similar so you can flash the ECU.
Next, plug in the Vishnu Xflasher.
Select a flash/map
Flash the map
Unplug the test connector and the Xflasher and drive your newly flashed Evo.
On May 22, Vishu will pass the official 60 day Vaporware designation...
Doug in Cincinnati
('03VIII, Vishnu1+, cusco rear sway, stainless brakelines, various shiny bits, Vishnu sticker, Shiv's and Punchard's fingerprints, and a Noble M400 for serious driving...
Doug in Cincinnati
Originally Posted by DaWorstPlaya
This might not even be released because of the availability of OpenECU and the harness that will esentially do the samething ...
An ETA yet?
Unless I missed something, the last post from Vishnu was in mid April and said it was in testing. Any ETA yet? I am holding off on getting a tune until it comes out. I want to be able to load a crippled map for when I go out of town, just incase my bro tries to "borrow" my car
shiv
