Conditional How-To: Lean-Run Protection
Old Jul 11, 2006 | 06:20 PM
  #31
freedom's Avatar
Well I had this problem occur today with an on the roll WOT in second gear from ~3200 RPM. Fuel was pulled at about 1.3 kg/cm2, thus in theory engine was still in spool up. The conditional configuration in the fuel map is identical to the first post in this thread.
I'm undecided on what to change at this juncture. Suggestions?
Edit: This problem never reoccurred, thus I haven't changed anything.
Originally Posted by Jorge T
Today after pulling out of Walgreens I punch it in 1st gear and around 6k rpm the engine cut out. Felt like conditional lean protect fuel(maf) cut. I have it set as per instructions, except for fixed value output set a 5% instead of 0.
LC-1 checks out fine, AFRs seem like always 11.8@3krpm to 11.0:1 over 6krpm in all gears except 1st where wideband trails.
Old Jul 28, 2006 | 11:25 PM
  #32
SuperHatch's Avatar
I fixed my transitional lean condition...
I fixed the problem I was having as described above...
Before:
After:
It was that simple. I was able to lower the lean run threshold to 600ms and still no fuel cut. I'm happy again...
- Steve
Attached Thumbnails Conditional How-To:  Lean-Run Protection-before.jpg   Conditional How-To:  Lean-Run Protection-after.jpg
Old Aug 14, 2006 | 01:52 PM
  #33
Evo23IG's Avatar
Is this final version of the Lean-Run Protection? Has anybody tried? Also bump for the pictures to work and being a sticky.
Old Sep 2, 2006 | 09:07 AM
  #34
Badog's Avatar
Yea i'd like to see the pics as well to make sure I'm setting it up right.
Old Sep 3, 2006 | 08:31 PM
  #35
gashero's Avatar
^+1
the picture are not there. I need to set up my conditional.
Old Sep 4, 2006 | 05:35 AM
  #36
freedom's Avatar
Here you go...
File Type: zip
File Type: zip
File Type: zip
File Type: zip
Old Sep 4, 2006 | 06:08 AM
  #37
gashero's Avatar
Thanks freedom. I will set this up.
