Vishnu Ohlins are here!
Old Mar 24, 2007 | 04:54 PM
  #121
Sharkbite2000's Avatar
Proper.
Old Mar 24, 2007 | 11:07 PM
  #122
DaWorstPlaya's Avatar
Originally Posted by kekek
All this talk of pulling strings has me excited again.
Me too bud ... And I have a local region auto-x today. Wish me luck
Old Mar 26, 2007 | 08:57 AM
  #123
LanEvoNine's Avatar
i'm hoping they come in soon, i want to run something other than stock on the tracks, limerock was cancelled for non-existent snow this weekend boohoo
Old Mar 26, 2007 | 01:51 PM
  #124
heeltoer's Avatar
hi all,
Im sorry if this has been answered already but Im wondering what the advantages are for swapping out the rear trailing arm suspension bushing? I have the bushings (also front +rear sway bar) in hand but have yet to install it. Are there longevity or failures related to not having this bushing?
Anyone have recommendations for shops that can install these at a reasonable rate?
BTW Ive run the Vishnus for two events in 2007 and at both events I got a track record (NASA Norcal TTB #42, Thunderhill+Infineon). This is an excellent suspension for the track. I also drove it last weekend in the hills and it was pure delight. Worth every penny.
Old Mar 26, 2007 | 06:46 PM
  #125
meanmud's Avatar
Originally Posted by heeltoer
hi all,
Responsiveness - less sponge
Old Mar 26, 2007 | 07:12 PM
  #126
Warrtalon's Avatar
Heeltoer, I couldn't give you the technical explanation, but I do know that Paul consider the bushings to give a .4s gain per lap.
Old Mar 26, 2007 | 10:15 PM
  #127
Erik@MIL.SPEC's Avatar
IIRC, the rear trailing arm bushings only have a "web" that attaches at 2 points. Any hard track use, and these bushings will break. John Mueller has seen it plenty of times.
Old Mar 27, 2007 | 04:44 AM
  #128
kekek's Avatar
You guys are correct about the trailing arm not being solid rubber. However that is not the bushing included with the Vishnu kit. Those are sway bar and rear lower control arm.
Changing the LCA bushing allows the suspension to work more effectively since the poly transmits more force faster than the squishy rubber. Like meanmud said it's more responsive.
Old Mar 27, 2007 | 06:58 AM
  #129
Tristar's Avatar
Any recommendations for bushing for the LCA since the Vishnu kit does not have them?
Old Mar 27, 2007 | 07:09 AM
  #130
Czubaka's Avatar
I put the energy suspension bushing in. Got it from RRE for $25.
Old Mar 27, 2007 | 07:38 AM
  #131
Tristar's Avatar
Do the LCA bushings need a press to install? I might do this before any other suspension mods. (Not like I can get the Ohlins right now anyhow, haha)
Old Mar 27, 2007 | 07:50 AM
  #132
Czubaka's Avatar
Yes, definitely. The biggest issue is getting the stock bushings out. You'll need a socket that's the exact same daimeter as the stock one because the bushing rides inside a steel sleeve. If you go too big, you risk damaging the aluminum.
For install, make sure you insert the bushing in the tapered side of the arm, then use the press to get it most of the way in (it will deform a lot initially, nothing to worry about), then use your thumbs to push it the rest of the way.
Old Mar 27, 2007 | 09:06 AM
  #133
jcnel_evo8's Avatar
Umm .. stock ones, or poly / aftermarket ones?
~j.
Old Mar 27, 2007 | 09:08 AM
  #134
Czubaka's Avatar
Stock ones. The poly ones are solid.
Old Mar 27, 2007 | 09:14 AM
  #135
kekek's Avatar
24mm Craftsman Impact socket works for me. And yes you def need a press to remove the OEM bushing.
