I got tuned*Updated w/Graph...
Old Sep 10, 2006 | 01:04 AM
  #46
Turd Squirter's Avatar
Alan...are you still running the stock spark plugs?
Old Sep 10, 2006 | 11:17 AM
  #47
alan678's Avatar
No I got the NGK Iridium IX (BPR7EIX) plugs...
From Lancershop.com - "Why NGK Iridium? More Durability and a Higher Melting Point compared to Platinum, better center electrode anti-oxidation and anti-erosion, improved ignition, superior anti-fouling, lower required voltage, new metal shell plating process for better anti-corrosion. These BPR7EIX plugs are recommended for EVO's with mild bolt on modifications. If you are running high boost or a large turbo you will want to go with the BPR8EIX spark plugs."
Old Sep 10, 2006 | 12:41 PM
  #48
Recks's Avatar
Lol you sounded like a sales man for ngk.... Lol.. Good job.. I really do wonder now why shiv's baseline is tuned so lean.. From my friends around here they say shivs tunes are actually pretty conservative..and I got that from 5 people running his tunes.. But I would rather have a safe good tune then an aggressive tune and my car mess up after a few runs
Old Sep 11, 2006 | 12:54 AM
  #49
alan678's Avatar
Well from what i hear, they use very similar maps for the 91 and 93 oct both using the same fuel map...that might be why it was lean for me as i was on 91 oct...but i truly dont know...good thing i got it worked out though...
