View Poll Results: Who is getting random misfire's CEL 0300 erros
I was just driving and it came on
101
54.89%
I was floored and looked up and it was there it was
18
9.78%
I got it when I left off the throttle
26
14.13%
I never get any CEL errors
39
21.20%
Voters: 184. You may not vote on this poll
0300 Errors / Random Misfire
Old Feb 8, 2004 | 06:47 PM
Stephen Fisher's Avatar
Tried the Vishnu plugs, and still have the problem. Please help if you have resolved this issue.
Thanks
Old Feb 13, 2004 | 05:14 AM
limey's Avatar
No cel but man it misfires a lot, every 15 mins on partial throttle
Old Feb 17, 2004 | 03:28 PM
EVO Neil's Avatar
I was getting this code on my stock Evo and the dealer resolved it by replacing the coil packs, plug wires, and spark plugs.
Old Mar 1, 2004 | 12:52 PM
GotBoost25psi's Avatar
hey is there anyway that i could get some info on that so when i take my stock evo in they wont give me crap, sayin that this has never happend to another evo before? thanks
Old Mar 2, 2004 | 03:54 PM
Stockfornow...'s Avatar
Just went to Jim Felts Mitsu in Sycamore, Ill to have my CEL diagnosed. It was the same "random misfire-PO300" that happened to my car ealier. After changing BACK to Mitsu OEM plugs/gap from the Vishnu recommened plugs the CEL came back on few miles down the road, after pulling into a drive thru lane at idle. Went back to the dealer and they called the Mitsu tech line. The end result of this visit is that Mitsu is in fact working on an ECU reflash to be released sometime in the future. They are "gathering data" before they send out a final reflash. No word on when this will be released, but it is definately a problem they are aware of.
So I guess, as of now we all just have to be patient or get a flash from one of the vendors out there and further void our warranties.
Just one more reason I will never buy another Mitsu product. I like the EVO but their quality control is really crap IMO.
Old Mar 21, 2004 | 08:02 PM
nutnbutturbo4's Avatar
ive gotten p0300 code too. my car is relivly stock just boost control. i even get it at running 10psi my fuel econ setting i dont even have an afc. just tries to find anything to use against fixing it. my friend is mgt in svc at . its sorry but thats what they do good thing i have a scanner so i can see and erase
Old Mar 29, 2004 | 08:15 AM
pwirski's Avatar
try using higher octane fuel (or mix with race gas). it solved my problem. i run my evo at a track and used to get p0300 after only about 5 mins of hard driving. now, before i head to the track, i fill it up with 102 oct race gas and have no problems.
Old May 19, 2004 | 02:09 PM
cdavy's Avatar
Registered User
Not getting it after the HKS DLI-2 installed... Yet..
Old May 19, 2004 | 07:20 PM
BJai02's Avatar
Vishnu gangs,
My car started to throw a P0300 code after 1500 miles... the only mod was a ground wire kit, which I don't think will attribute to this error code.
My question is, if Mitsu really came out with a reflash to fix this problem, will your X-Flash overwrite what the factory did with a new software?
Old May 19, 2004 | 09:07 PM
shiv@vishnu's Avatar
If Mitsu comes out with a reflash, there is a chance that it will overwrite any aftermarket reflash, our XFlash included. If this happens, just tell us and we'll reflash your performance related tables back to what it was before. You will still have the factory updates/PO300 fix.
shiv
Old May 19, 2004 | 11:16 PM
delkat's Avatar
My car has been throwing this code for the past couple of months. I can feel the car missing at partial throttle cruise - 34-3500RPM @ 75mph. New plugs didn't help. Runs fine at full throttle, but misses intermittantly at cruise.
Old Jun 3, 2004 | 12:53 AM
559EVO's Avatar
I get it too,I hope there's a solution soon.
Old Jun 3, 2004 | 08:42 AM
alex_alex's Avatar
i have had my car for 17000 miles, and have never had that cel come on until i drove up to the bay area (5 hours straight at about 100mph). Any recollection as to the context in which your CEL came on?
Old Jul 7, 2004 | 10:08 AM
sir lurks alot's Avatar
mine has only come on after letting the car sit at least overnight and then immediately getting on the interstate and driving for 15-20 min then it comes on. Doesn't happen all the time, maybe once a month.
Old Jul 12, 2004 | 11:39 PM
Turbocake's Avatar
sir lurks alot,
how long does the light stay on? does the car need to just get all the way cold again, or is it a period of days?
tia
