Shiv Man Cam Sensor Errors
Old Jan 3, 2004 | 11:34 AM
j3revo8's Avatar
hello shiv(vishnu)
service engine light..
i used my obd ii log and i received 4 seperate codes: 'cam angle sensor errors'
i cleared them. but whats up?
i have stage0+dp ?
thx my friend-jeremy
Old Jan 3, 2004 | 12:01 PM
shiv@vishnu's Avatar
Cam angle sensor error? Did you ever try unplugging your XEDE while the engine was running. If you did, it will throw that code. Go ahead and erase the code as see if it comes back.
Shiv
Old Jan 4, 2004 | 05:37 PM
j3revo8's Avatar
SHIV, i already cleared the codes twice, it only comes on w/ service engine light and 4 cam sensor codes when i stall in first gear. maybe ill roll to vishnu soon and have you check it out, do some tuning, and buy some goodies. THX
Old Jan 4, 2004 | 09:42 PM
MP5's Avatar
MP5
In Timeout
Its the stall bro dont do it!
Old Jan 4, 2004 | 09:49 PM
DynoKing's Avatar
In Timeout
Why does your car stall?
Old Jan 5, 2004 | 11:07 AM
j3revo8's Avatar
because i suck at stick driving. im getting better and better. it seems on the evo the clutch point is higher up. my bros wrx is a lot easier to drive.
Old Jan 5, 2004 | 12:10 PM
Smogrunner's Avatar
MP5, what do you mean: "Don't do it." Don't do what?
Hey Dynoking, sorry to see you got temporarily muzzled. Hang in there.
I bet your brother's WRX is an automatic, because my WRX w/5speed was a pain in the ***. It wouldn't stall, but it would continually bog horribly unless you feather and gas just right. It was so weak in low rpms - one of the main reasons I got rid of it.
When my EVO was absolutely stock, it stalled twice and came close to stalling a few other times. It happened mostly at drive-thru lines when I would have to move forward and then stop, not because I wasn't used to the clutch. With my xede, I stalled once because I let the clutch out in soft dirt without enough gas: but no SES light. However, the Xede, as of yet, doesn't fix the stock stall problem. It still comes close to stalling once in a while, just like when it was stock.
Good luck.
Old Jan 5, 2004 | 01:25 PM
Aby@MIL.SPEC's Avatar
Just work on the nut behind the steering wheel & the stalling should vanish.
Old Jan 5, 2004 | 01:30 PM
MP5's Avatar
MP5
In Timeout
Good luck.
I ment dont let it stall out
Old Jan 5, 2004 | 03:10 PM
j3revo8's Avatar
FLAMMING WOT? MY BROS IS A STICK WRX BUT IT HAS STAGE ONE COBB UPGRADE.. ANYWAY THX FOR THE REPLIES.
Old Jan 5, 2004 | 03:15 PM
MP5's Avatar
MP5
In Timeout
No we could all benifit from neing torqued. You cant drive well you said it and Im a little concerned about you having 275 Ft/Lbs on tap. In fact Im concerned when I ride with anyone that is spiritively driving and cant rev match downshift a gear much less stalling the takeoff. Nothing against you but you know you need a torquing
Old Jan 5, 2004 | 04:28 PM
Relax, In case you have forgotten. Read your quote.
Just try getting the car rolling without giving it any gas in a flat parking lot somewhere. Dont worry about the clutch getting thrashed, because your not applying a massive load. Thats the best way to learn about clutch lever feel & clutch engagement. If your car idles to low, raise it up to 1,000 & practice.
Old Jan 5, 2004 | 04:30 PM
j3revo8's Avatar
thanks for the tip WOT. im cool. later
