Stage package interchangeability
Old Jan 6, 2004 | 05:32 PM
johnnyevo's Avatar
Shiv,
For your stage packages, what do they all share together. Eventually i'd like to wind up with stage 2, but would like to get there progressively. I don't want to buy parts that will only be not used in a later stage. All I can think of now is that they all use the same following: 1) xede 2) fuel pump 3) cam gears 4) cams. Is that it?
Also what is your take on the cam situation? What are the pros/cons to running 264/264, or 264/272, or 272/272? Your currently running the 272/272 setup right?
Thanks again for the info! Keep up the good work!
John
PS Hows the intake coming?
Old Jan 6, 2004 | 05:38 PM
MP5's Avatar
MP5
In Timeout
Re: Stage package interchangeability
Originally posted by johnnyevo
Shiv,
John
Hey Johnny through stage 1+ all parts build upon each other. IIRC the downpipe does not need redoing so in essece all parts should built upon each other through stage2. BTW stage 2 is for sick depraved people! Stage 1+ works very well for me.
the staggard setup really maximizes the stock turbos effeciency. IMHO 264s arent worth the effort and expense. 272s might be in the future and I would run them with a bigger turbo.
I always tell people that really in truly stage 1+ is sick- It makes for a very fast car and I wouldnt be supprised to see very low 12s maybe a high 11 soon
Old Jan 7, 2004 | 06:52 AM
Eric Lyublinsky's Avatar
Shiv,
John
John MAC!!
Ever part of stage 1+ will be used in stage II. I do know the down pipe will be diffrent.
272/264 looks like the winning combo but if your looking to do the stage II (witch you might not be after driving a Stage 1+ car with over 340whp DYNOJET) then 272/272 would make better sence.
We should meet up soon. I want to give a quick ride with my new mods.
Eric
Old Jan 7, 2004 | 09:28 AM
GokuSSj4's Avatar
Eric what are some of your new mods? , since last time all you had was the Xede and a catback from Vinshu.
Also wont the 272/272 combo (for idle issues ) would be better ran on EMS , since a friend of mine has that set up and it iddles stock or near stock.
Can the Xede with the Flash do that ??
An went upgrading to the 264/272 staggard cam combo . do you need to upgrade to ARP head studs ???
Old Jan 7, 2004 | 11:33 AM
I changed my Exhuast and now have a full 3in turbo back with highflow cat. I have cams just waiting for a 93oct base map for Xede. 272/264 combo BTW.
Shiv can make the car idle with X-flash perfectly. I will be using the combo xflash and xede. Do you need to upgrade to ARP head studs? well that's not a bad idea and also you should upgrade the fuel pump when doing cams IMHO.
Old Jan 7, 2004 | 02:18 PM
shiv@vishnu's Avatar
I don't know about 'perfectly' but certainly 'better than expected'
The term perfectly conjures up the notion of being unable to tell a cam'd car from a stock car. While most folks wouldn't be able to distinguish between them, I think some people will notice the difference (although slight, of course).
Cheers,
shiv
Old Jan 7, 2004 | 02:20 PM
Cheers,
shiv
Ok how about this.
Shiv can get them to idle just about perfectly.
Old Jan 8, 2004 | 06:45 PM
johnnyevo's Avatar
Whats up Eric!
You know me, there's no such thing as enough power. Stage 2 should fit the bill for a daily street driver! Definitely will be meeting up when the weather breaks, I'm really impressed with this car! I wish I never wasted my time with the WRX, but then I wouldnt have met you, or shiv, and, whatever!
Talk to ya soon,
John
PS Eric STILL doesnt have his MR2 running yet
