cam gears
Old Feb 16, 2004 | 09:37 AM
asasin79's Avatar
cam gears
Please help. i am having cams and gears installed right now and brice from alamo is asking me what the red marks on the gears are for. please help
vincent
(972)977-6231
Old Feb 16, 2004 | 10:12 AM
MP5's Avatar
MP5
In Timeout
Re: cam gears
vincent
(972)977-6231
I called Brice Vincent
Old Feb 16, 2004 | 04:41 PM
asasin79's Avatar
thanks homie. we did them like this except at -3. but these don't have the red dot.
Old Feb 16, 2004 | 07:00 PM
Noize's Avatar
EvoM Administrator
Re: Re: cam gears
Can you share with the class, MP5? I'm attacking this on Saturday and want to be sure I get everything right. -5/-5
Old Feb 16, 2004 | 07:13 PM
DEL TURBO's Avatar
Red dot is zero degrees on the Vishnu gears. Don't line up the gears with the 0 degree mark. They're one tooth off due to the difference between the Evo and DSM gears. If your Stage 1, -5 is the correct setting. I'm running -3 with Stage 1+. Just set your degree on the gears, install both gears with red marks lined up with valve cover marks.
Old Feb 16, 2004 | 07:24 PM
BadBoyBeltran's Avatar
They are off by one whole tooth on the cam gears?!? What is the exact zero point (in degrees) for our EVOs?
Thanks.
Old Feb 21, 2004 | 05:58 PM
asasin79's Avatar
i have not driven my car since the 16th and am adjusting gears now but want to know if they were installed with the 0 degree slash up that means they are @-10 degrees so i need to move them to +4 degrees to get them @-3, right???
thanks guys
Old Feb 22, 2004 | 07:26 PM
asasin79's Avatar
bump
Old Feb 22, 2004 | 07:47 PM
Noize's Avatar
EvoM Administrator
thanks guys
No!!!
Degree them to exactly where you want them. If you want them at -3. set them at -3. There are marks on the valve cover under the timing belt cover and the red dots on the cam gears are where to align them.
Repeat: If you want -5, set to -5. -3, set to -3. -2, set to -2. If you set it to +4, you'll be way off for the map and possibly put the engine in danger.
Old Feb 22, 2004 | 07:50 PM
Smogrunner's Avatar
Here is a good photo of what your gears should look like when set at -2. Use this for reference. They are installed correctly.
Old Feb 22, 2004 | 07:51 PM
Use the dots to get to TDC!!! Use the marks (-2, -3, etc) for timing adjustments!!!
Old Feb 22, 2004 | 09:08 PM
asasin79's Avatar
well from my understanding one tooth is 7.5 degrees so moving them to +4 would make them -3. this is an option without taking them out and realigning them at tdc. just looking for an easy option here.
Old Feb 22, 2004 | 09:09 PM
shiv@vishnu's Avatar
Sounds right to me.
Shiv
Old Feb 22, 2004 | 09:15 PM
asasin79's Avatar
thanks shiv! check your pm my xede does not always turn on, sometimes i will have a red light. i need help with that aswell.
vincent
Old Feb 22, 2004 | 09:18 PM
vincent
Yep... I got it. Could you pm me your XEDE's serial number? It's written on the XEDE case.
Cheers,
shiv
