Off To Detroit for C&D SuperCar Challenge
Originally Posted by shiv@vishnu
Hi guys,
As Eric said, the engine block is internally stock with the exception of rod bolts and headstud. The head, however, has been worked over with larger valves, porting, springs, retainers, cams and gears. We are running an upgraded intake manifold as well.
Take care,
shiv
Take care,
shiv
That's the way to do it. OEM reliablity fit and drivablity as far as the motor goes.
With the extra safty, rod bolts and head studs.
autoathorty's stage III 993 turbo is just sick. I got to drive one once and with 607hp it's just nasty. 3000lb 1/4th 10.1@143 on pump gas with only 1.2 bar of boost. 3.6l. HOT DANG it cooks. It's not a cheap car to mod ($6,000 intercooler upgrade) but the stock rods are good for 700hp all day long.
Eric
I should be allowed to disclose the general results well before it goes to print. I'll ask the C&D guys if it would be okay to spill the beans early (like next week
) I don't think they are too fussy about test result leaks on the interent. Trust me, if we beat at least one car, I'll make a public announcement and rent a sky writing plane.
Shiv
) I don't think they are too fussy about test result leaks on the interent. Trust me, if we beat at least one car, I'll make a public announcement and rent a sky writing plane.Shiv
Make sure you bring us back tons of pictures Shiv! I shoulda lent you my camera so you could have sound with the video... Ya know, you should have a video camera mounted in there somewhere..
Terry
Terry
Shiv
Shiv
From what I hear your a good driver Shiv so I think you will do really well against the big dogs.
Good Luck
Thanks but I'm not driving. We're leaving that to fellow evom-er Chronohunter (Paul). When it comes to driving, he's just a teeny tiny bit better than me
Originally Posted by dsmshane
Shiv, good luck. Even if you don't win
for representing the evo world.
And Paul has driven this event before. I'm sure his experince will be also very helpfull.
But Shiv's no dud. The guy can drive the crap out of anything. Hell I don't even like driving with him in the same car.
Shiv. Here is the url for skywriters in your area.... http://www.onpoint-marketing.com/aerial-advertising.htm I'd imagine you will need em...
Good luck!
SC~
Good luck!
SC~
