CEL eliminator?
CEL eliminator?
Hi guys,
The Aussie boys are hard at work. I can't even get them to break away from their laptops. The features we are implementing are pretty incredible. But we need some info in order to incorporate the cat efficiency CEL fix into the XEDE.
Has anyone found a wire-in CEL fix (to the rear o2 sensor) that works perfectly? That is, has anyone installed one on their cat-less car does not trip a cat efficiency CEL? If so, how long have you run it and what unit is it?
Thanks,
Shiv
Thanks,
Shiv
Not wire in....of course you know the "space the 02 sensor" trick that is floating around seems to work perfectly?
I have been running it with test pipe, race gas, ....not even pending, even when cruising..
used to get the P0420 all the time...
I've had the Perrin test pipe with the O2 Wire-In simulator on my car for 7k miles now and have had no codes come up.
- Steve
- Steve
Originally Posted by Steve who just edited his post to add this in:
I have a 0+ car w/ XFlash not Xede. HKS Intake as well... I don't know if these mods effect the rear O2 readings.
Yes!! I'd love to test it and incorporate something like it into the XEDE harness
shiv
shiv
Originally Posted by jsotican
Shiv:
I've got a Casper O2 simulator that I can send you. I'm not using it now that I'm running a Random Technologies high flow cat.
It is yours if you want it.
Best Regards,
JS
Best Regards,
JS
Originally Posted by Jorge T
So the 02 sensor spacing worked? I'm thinking of doing that when I get my dump back next month.
I know of three Evo's running this with test pipes and all are having no CEL once installed here in my area for several months.
