CEL eliminator?
Old Nov 17, 2004 | 06:15 AM
  #46
UncleXSO's Avatar
Sorry to bring up an old thread here. But, I am looking into a CEL eliminator. I have the Meagn racing setup for exhaust with the Xede and Vishnu cam gears. I welded in an O2 sensor bung to keep the O2 sensor in, but I just installed the cat delete and I amthrowing the CEL. I tried the mechanical fix but, unfortunately I don't have enough room (Run into the floor board).
To get to the point here, has Vishnu come up with the CEL patch discussed in this thread??
Thanks!
Old Nov 17, 2004 | 09:52 AM
  #47
cooter's Avatar
Originally Posted by UncleXSO
Sorry to bring up an old thread here...
Damn you! I sat and read that whole thing thinking it was a recent issue...
Time to wake up...
Old Nov 17, 2004 | 09:54 AM
  #48
rich728's Avatar
the P0420 code doesn't affect performace right?
Old Nov 17, 2004 | 10:41 AM
  #49
shiv@vishnu's Avatar
It's done. We have 50 in stock. Wait until later today and I will post pricing and installation process. We designed it so that it will install on the XEDE harness. No need to cut/splice into stock wiring or o2 sensor harness. Takes about 2 minutes...
Shiv
Old Nov 17, 2004 | 11:48 AM
  #50
meanmud's Avatar
This is the 02 code right?
Being catless causes some Zany-**** harmonic pitch that throws my P0200 code - will this work for me "Dazed & "
Old Nov 17, 2004 | 11:58 AM
  #51
UncleXSO's Avatar
Sweet! This makes me feel all warm inside. Put me on the list!
Old Nov 17, 2004 | 12:35 PM
  #52
Ludikraut's Avatar
Ditto.
l8r)
Old Nov 29, 2004 | 03:26 PM
  #53
Jorge T's Avatar
I got mine...Need instructions
Old Nov 29, 2004 | 03:53 PM
  #54
David@Vishnu's Avatar
Short and nasty of it is if you unplug the far left connector of the ECU, (this is the xede harness/factory ecu junction) Bend the white connector (the one we supply with the xede)toward you (so that the wires are pointing toward the firewall) it is the 5th wire from the RIGHT. You remove this wire just like the boost wire, stick the connector from the 0420 elim in the connector then connect the factory wire to the other wire on the 0420 elim then finally ground the black wire
Old Nov 29, 2004 | 05:00 PM
  #55
Jorge T's Avatar
Thanks! I will install it tomorrow along with a test pipe.
Old Nov 29, 2004 | 05:23 PM
  #56
Jorge T's Avatar
__[]_[]_________[]__[]_
|00000000000000x0000|
|0000000000000000000|
Plug orientation is like this when unpluged and bent toward you and wires facing firewall. 5th wire from the right is one with the x.
Plug is not to scale .
Old Dec 1, 2004 | 11:11 AM
  #57
UncleXSO's Avatar
Can someone take a pic of this particular wire? I am having a hard time tring to decipher which one to pull. I would really rather not take a chance and pic the "automatic driver ejection seat" wire or something.
Old Dec 1, 2004 | 11:29 AM
  #58
Jorge T's Avatar
see above
Old Jan 21, 2005 | 10:51 PM
  #59
RogueSTi's Avatar
Pic: Sorry so fuzzy, but what you're seeing is the white ECU plug from the Xede. 5th pin over from right has the CEL eliminator installed. Hope this helps.
jallways
Nov 19, 2014 11:11 PM
nick9g4b1
Lancer Engine Management / Tuning Forums
10
Jan 8, 2012 10:16 AM
Ralliart Lancer
Apr 6, 2006 07:29 PM
