Xede bank switching
Old Sep 4, 2004 | 06:14 PM
Jorge T's Avatar
Xede bank switching
Instructions are not clear...to switch banks, do I need a toogle switch to ground the wires all the time to use bank 1 or do I use a momentary switch (that returns to a open circuit) just to ground wires to switch banks ? TIA
Old Sep 4, 2004 | 06:16 PM
eazyevo's Avatar
The wires have to stay in contact. A momentary switch wont work. A toggle switch should do the trick.
Old Sep 4, 2004 | 06:28 PM
Event-Horizon's Avatar
I use a small on/off toggle switch that I bought from radioshack. I zip tied it to the ECU harness and it is protected by the ECU wiring harness cover.
Old Sep 4, 2004 | 08:44 PM
Jorge T's Avatar
Thanks! On to Radio Shack will be.
Old Sep 5, 2004 | 06:49 PM
Jorge T's Avatar
finally..racegas rocks
Old Sep 5, 2004 | 07:00 PM
shiv@vishnu's Avatar
Old Sep 5, 2004 | 07:01 PM
shiv, can you please check your PM. Thanks!
Old Sep 6, 2004 | 05:08 PM
Jorge T's Avatar
...and the little switch that makes it happen
Old Sep 6, 2004 | 05:12 PM
David@Vishnu's Avatar
Nice good call on marking the "Hot" side
Old Sep 6, 2004 | 05:22 PM
Smogrunner's Avatar
Call me ghetto but I'm afraid of a switch. I don't want to switch it inadvertantly. I'll just keep the red in the glove box and the black right behind the glove box and put'em together when it's time to lay down a little smack.
Old Sep 6, 2004 | 05:57 PM
Jorge T's Avatar
white is 93, green=go 104! I made sure I did not forget...
Old Sep 6, 2004 | 06:24 PM
eazyevo's Avatar
In the event that the switch IS hit inadvertently, is there any fail safes built into the xede ? Or would it be catastrophic ?
Hitting the switch for 110 or C-16 running 93 octane per say.
Old Sep 6, 2004 | 06:27 PM
alex_alex's Avatar
Thats why i'm planning on using like 5 switches, all of which have to be turned on to activate the race map
Old Sep 6, 2004 | 07:00 PM
eazyevo's Avatar
Nice idea I think I'll do the same.
Still curious of the effects on the engine in an inadvertent map switch
Old Sep 6, 2004 | 07:10 PM
alex_alex's Avatar
well, from what i understand, the Xede still retains much of the factory ECU's safegaurds against situations like this, and i think the engine should be fine as long as its not running pump on a race gas map for an extended period of time. The ECU would, in theory, adjust and just cause the car to run like sh_t
