XEDE tuning
Old Sep 16, 2004 | 12:52 PM
93civEJ1's Avatar
XEDE tuning
What does the actually tuning interface on a laptop look like? Any pictures, and also, how confusing is using the XEDE?? I am hoping to get one during the next Dyno4mance Dyno day in October.
Old Sep 16, 2004 | 01:18 PM
lambtron's Avatar
If you picture a digital equalizer, that is what our tuning interface looks like. Just make the curve look pretty and you'll make gobs of power....
..j/k LOL
Old Sep 16, 2004 | 02:04 PM
earthman's Avatar
uh huh ........ sounds like something Ol' Al wud say !!
Old Sep 16, 2004 | 02:08 PM
Ludikraut's Avatar
There are a few screenshots here (not the main screen though ) ... http://www.vishnutuning.com/files/ev..._Map_Files.doc
You could also try www.chiptorque.com.au and see if they have any screenshots of the XMap software.
l8r)
Old Sep 16, 2004 | 04:13 PM
ez76's Avatar
This file has screen shots and instructions:
e.g.
Old Sep 16, 2004 | 04:36 PM
nirvevo's Avatar
There is also a "Live Data" interface (I think that is it's name) That shows a bar style read out for a few other items (MAF MAP Wastegate Solenoid (I think?) etc...) along with the same RPM half circle. You can only get data from maps that are not password protected. I don't know if Vishnu's are or not, I am running on a local (mile high altitude) map up here in Colorado. For instance you might get MAF in but not MAF out.
It also has a logging feature that will go into an excel spread sheet pretty handily but from there you either have to love reading long lists of numbers or know how to pull it in to a readable chart in MS Excel.
There is also something called (something like) "auxillary injector duty cycle". Which I can't get to work.
It looks like a pretty cool tool but I would like to have some documentation on it as it applies to us Vishnut's. The help file also serves as a user's guide. I am just starting to use it, so I'm pretty green on it.
Good Luck :-)
Old Sep 16, 2004 | 08:13 PM
Streetrcrm3's Avatar
Does any of this stuff work on a mac by any chance?
Old Sep 16, 2004 | 08:28 PM
n00dle's Avatar
With VirtualPC.
https://www.evolutionm.net/forums/sh...light=xede+mac
Old Sep 16, 2004 | 09:21 PM
Talking
Awesome.
Old Sep 17, 2004 | 12:41 AM
MayhemSi's Avatar
I also run it on a mac. Its very important to get a good usb to serial adapter though. I run a keyspan. It was a little more expensive but the cheap targus one didn't work at all.
Old Sep 17, 2004 | 04:52 AM
sr20det91's Avatar
You can always download the the xmap software from Vishnus site. Thats what I did before I ever got my xede, I just browsed around the prog to get familiar with it. I think it helped alot,for when I finially did get everything installed.
Old Sep 17, 2004 | 05:49 AM
MayhemSi's Avatar
Tuning the xede is very easy (at least at my level of tuning where safety instead of every last horsepower is important). I am using a plx wideband setup and my mac and after about 4 tries, I got the map sitting where I wanted it in this texas heat. I DEFINITELY say you need to hook a wideband up if you are running an intake of any kind. This will cause the maps to be much much leaner (at least in my experience) and they need to be fattened up a bit.
Old Sep 17, 2004 | 06:56 AM
Smogrunner's Avatar
Ludakraut, change that purple background. LOL
Old Sep 17, 2004 | 08:38 AM
Ludikraut's Avatar
Dewd, wrong ludikraut ...my background looks a lot more like my avatar, hehe.
l8r)
Old Sep 20, 2004 | 10:35 PM
Jorge T's Avatar
So retarding .5 deg on the timing table takes out .5 deg of spark advance or 1 deg of spark advance?
