Buschur/Dynoflash/SMC alky kit problem?
7 gph vs. 15 gph. Just less than half the flow. The 15gph was actually made for the Buick market which is atleast 3.8 liters, engine size.
David Buschur
www.buschurracing.com
David Buschur
Well, has anyone thought that maybe this lack of stumbling is related to the #7 nozzle instead of the nozzle people used to use?
IMO, insufficient to ward off knock at the track at full tilt. Maybe for 24-25psi peak at conservative a/f's, but not a big boost spike like Dave used to run when running the the spikes on the dynotesting thread.
Especially in 1st gear on the launch. We started with 5gph, then moved to 10gph + a little 110, then to fully use 93+meth alone with no racegas, it took a 15gph to finally see the timing numbers stay put on a drag run.
Vtechh8ter and many others use the 15gph.
If tuning with the assumption that a end user may run out of meth or pop a leak however, the 7gph + conservative a/f is the way to go.
Originally Posted by TTP Engineering
You have to know how to tune it, for it to work. Slapping on a meth kit and hoping for instant power is not going to work.
TTP,
Not sure if you meant "Dave" as me or not?
The #7 nozzle I feel is perfect. We played with a few different nozzles and this one seemed to work best.
When I tune a customers car, or Al for that matter, I won't go over 25 psi on pump gas and alky. I feel that is really the upper safe limit given the fueling, variances in octane you get and he safety of something failing. So I guess with you stating 24-25 psi is fine with this nozzle it explains why that's what I use
David Buschur
www.buschurraing.com
David Buschur
I see, 7gph. Many referred to it as #7.
You are correct, i do run the 15gph nozzle but Dave has changed my mind on that as it is too much Meth for the car. In turn their is no room for error in the event something happens to the system. I have personally replaced 3 motors on evo8's due to this same thing happening. Everyone that runs alot of meth is just on borrowed time
.It is fun to crank up the boost to 30 psi on the stock turbo with the meth, but it is not worth it IMO as anytihng can happen. I am stepping down to a smaller nozzle and relying on pump gas more these days
.Also the way my car is setup now, their is no need for all that Meth
Originally Posted by cfdfireman1
You’re asking to believe that your evo is running partially on fission?
heheh. very cute. unforunately, your assessment is wrong. what he is describing is a chemical reaction, not a fission reaction. splitting an atom is fission. splitting a molecule is a chemical reaction. water is a molecule, not an atom.
cheers,
strike
cheers,
strike
cheers,
strike
-shiv
Originally Posted by VTECH8TR
...... I have personally replaced 3 motors on evo8's due to this same thing happening. Everyone that runs alot of meth is just on borrowed time ......
I know there still is the possibilty of disaster if a combination of malfunctions occur furthermore the phenomenon of WG actuation time lag may not be soon enough, but would this be fairly "safe"?
I just realized I made an off-topic post, oops
I think some type of safety chart should be devised for people to go with. Say 7gph is good for X psi and 10gph is good for X psi and so on. The pump gas octane should be fed into the equation also since some of us run 93 and some run 91. And the difference from running alcohol, meth, and combo with 50/50 users.
Any/all- What nozzle would you recommend for a GT35/100% denatured/92oct rig? I have both sizes and am not sure which is appropriate. Also, what is the max reliable boost to push the 35R to on 92oct assuming the SMC kit IS working? I also plan on running my AEM EMS to not go to the alternate map unless it gets the spray signal indication...should give some safety.
I think you will have to talk to who tunes your EVO on the nozzle size. Too many tuners have too many different ideas on how to do it. Leave it up to the guy that will be responsible for the car when it has a problem.
David Buschur
David Buschur
Well, has anyone thought that maybe this lack of stumbling is related to the #7 nozzle instead of the nozzle people used to use? I haven't been keeping track of alky since I hadn't planned on doing it for a while, but then one fell in my lap, so here I am. I thought that they recently started doing the #7 nozzle for additional safety and was wondering if that would be the reason why our cars aren't stumbling with the use of the test button...as if the amount of injection isn't quite enough to cause the engine to choke.
I will test the dipswitch settings to see if I see 100psi instead of 80psi. Anyone else have any suggestion on this? Do we want/need to see 100psi when testing?
My first runs on the dyno showed AFRs in the 9s, so I knew it was working despite the nozzle being tapped into the stock IC pipe up by the battery, which isn't very close to the TB.
Warrtalon,
How are you planning to compensate for the lower AFR's? SAFC?
I had the same problem with my smc alky pump pressure initially showing 80psi and was road tuned this way. My AFR were 10.6-11.0 @25psi with no knock, so I figure its safe at 80psi. But I'm wondering if I'm leaving a margin of saftey and a few hp on the table at the lower pressure.
After calling SMC about this and flipping dip switch #1 the pressure went back up to 100psi. Now I need a way to re-tune it.
Kinda makes me wonder if SMC tests every pump/controller before shipping them.
