SMC Kit not working all the time
Old Feb 2, 2006 | 05:36 AM
Atlmethevo's Avatar
Okay I drive my evo about 1-2 times every few weeks, when I 1st got this kit installed it worked fine, now it seems like I have to prime it a lot to get it working when I do not drive the car everyday. Is this normal? The problem I am having is the kit is not spraying at all unless I hold the test button down for 5+ seconds then it works untill I shut the car off, next time I get in the car the kit does not spray until I do this again. Any ideas?
Old Feb 2, 2006 | 05:58 AM
GTVEVO's Avatar
If the system is not staying primed all the time you have a leak somewhere. I would start testing the system probably out of the car to find the leak. Do this with water only of course. You might have to leave it out to test for a few days even.
Old Feb 2, 2006 | 04:41 PM
spyonu2007's Avatar
Verify that the check valve hasnt crapped out on the line, prior to the spray nozel.
Old Feb 2, 2006 | 06:01 PM
HxllxMan's Avatar
Interesting, I do not drive daily drive the car... sometimes a month. Do methanol get clog or whatsoever? Not good to let methanol sleep in the tank?
Old Feb 2, 2006 | 07:45 PM
DynoFlash's Avatar
i would remove check valve
Old Feb 10, 2006 | 08:36 AM
Steve@NoLimitmotors's Avatar
I would contact Steve at smcenterprises.com and ask him what to do
IraqFire88
Jan 10, 2013 07:10 AM
9evolution
16
Jan 20, 2011 11:57 AM
Clark_Kent
For Sale - Miscellaneous Automotive
May 2, 2010 10:22 AM
Pure Playaer
45
Jan 19, 2008 07:38 AM
smokedmustang
Aug 17, 2006 06:45 AM
