5th Injector, Methanol, and AEM EMS
Old Jan 6, 2007 | 06:39 PM
DarksideEng's Avatar
I searched and couldnt find anything relating to this. Would this be possible using this setup for the injector?
http://www.atpturbo.com/Merchant2/me...egory_Code=FUL
I could run a line from my meth pump (SMC Kit) now to the injector, then have the AEM run the 5th injector, come on at a set time, increase duty cycle as boost rises, etc. Im not 100% sure the AEM could do all of this but I just thought I would run it by you guys. I would weld the injector in my up-pipe where the nozzle is now.
Sound like a good idea or a waste of time? It just seems an injector would work better than the typical nozzle.
Old Jan 9, 2007 | 09:14 PM
Aliengotpsi's Avatar
Sounds like a great idea!!
Old Jan 10, 2007 | 08:47 AM
GTVEVO's Avatar
You can do this , several supra owners do this and have a kit put together for it. Just search for it.
Old Jan 10, 2007 | 08:50 AM
Cool, Ill search for it. Also, another week or so and I will ask you to get together the ignition stuff.
Old Jan 10, 2007 | 09:33 AM
GTVEVO's Avatar
Sounds good
Old Jan 11, 2007 | 03:07 PM
jbrown's Avatar
Let us know what you find!
Old Jan 21, 2007 | 06:52 PM
I couldnt find anything . Anyone wanna help?
Old Jan 23, 2007 | 03:29 PM
94AWDcoupe's Avatar
Fuel injectors dont last very long spraying methanol. Plus that injector holder is not meth compatible either. If you used ethanol which is far less corrosive it would work very well. The aem can control an additional injector setup with unparralled acuracy.
Old Jan 23, 2007 | 03:37 PM
SlowCar's Avatar
how do you ensure that the single injector will give you enough dispersion to send a good distribution of alky mist down each of the 4 runners?
Old Jan 23, 2007 | 03:54 PM
Turbo Kyle's Avatar
I also heard you can use AEM to control the pump voltage of an alky pump.
Old Jan 23, 2007 | 04:52 PM
SlowCar's Avatar
even better...if the AEM can be used to control a high speed valve like the one from aquamist, capable of open/close, 250 times a second....rather an a massive rotating chunk of steel and copper pump rotor?
Old Jan 23, 2007 | 06:01 PM
94AWDcoupe's Avatar
You have to use a solid state relay to control the pump like an injector. The output on the AEM is for an injector. Injectors are driven at 5 volts. You cant drive a 12v fuel pump on the 5v output. Driving a FP like an injector is of course to where near as affective as driving and controlling an injector.
Old Jan 23, 2007 | 06:09 PM
Turbo Kyle's Avatar
Just what I heard from a supra owner....im sure thier are better ways to do it.
Eisen7
Apr 6, 2014 08:15 PM
OakosAutomotive
EvoX 'For Sale' External Engine / Power
41
Aug 16, 2013 12:47 PM
OakosAutomotive
193
Nov 2, 2012 09:08 AM
OakosAutomotive
110
May 14, 2010 12:02 PM
kungfugirl
Lancer Aftermarket Forced Induction Tech
Oct 10, 2007 02:07 PM
