Alky < Meth? ...getting knock with alky...
Old Jan 25, 2007 | 06:07 PM
scheides's Avatar
EvoM Moderator
Interesting. Are there alrternative settings to the SMC controller that can help this? I currently have it set at 10/20...perhaps 7/15?
Old Jan 25, 2007 | 06:09 PM
SlowCar's Avatar
some guys on here are making the progressive spray work like a on/off to get rid of the problem
Old Jan 25, 2007 | 09:05 PM
Evil_1's Avatar
Are you saying that you have yours set to come on at 10psi and max at 20psi? Mine is set to trigger at 16psi and max at 26psi. I think you'll want the max to be at 26psi for high boost. If you don't have a wide band hooked up, I wouldn't recommend changing those settings. Throw the BPR8ES in there and see what happens first.
Old Jan 25, 2007 | 09:17 PM
scheides's Avatar
EvoM Moderator
Like I said, I already swapped in the BPR8ES's. Wouldn't changing the controller to 16/26 make it start spraying later? I think my problem is that it's not starting soon enough, and that and that is resulting in not enough alky being sprayed as high boost hits.
If I run through the gears, the line is primed and the pump is only off while I shift, resulting in less knock throughout the power band.
Old Jan 26, 2007 | 01:17 AM
SlowCar's Avatar
the stock turbo is very fast spooling, hits full boost @3200rpm!
the massive pump rotor just simply cant react fast enough
Old Jan 26, 2007 | 05:15 AM
Evil_1's Avatar
Yes changing it to 16/26 would make it spray later than what yours is set at. Maybe it's the max point setting, that is probably what's limitting you from not getting enough alky. Why don't you contact the vendor you bought the unit from and see what their recommendation is?
Old Jan 26, 2007 | 11:20 AM
scheides's Avatar
EvoM Moderator
So I moved it down to about 7/15 and at 25psi knock is almost eliminated. However, as soon as I bump it up to 26psi, things get a bit unstable although not as bad as before. One run will be clean, 0 knock all the way through, the next will be knocking up to 6-8 counts. Here's a log from a clean run:
RPM O2 TPS KnockCt TimingAdv
2031.25 0.897 81.96078431 0 16
2125 0.9165 100 0 15
2218.75 0.936 100 0 13
2312.5 0.936 100 2 11
2375 0.936 100 2 11
2500 0.936 100 2 9
2593.75 0.936 100 1 9
2718.75 0.936 100 2 8
2843.75 0.936 100 2 6
2968.75 0.936 100 1 4
3093.75 0.936 100 1 2
3281.25 0.936 100 1 -1
3468.75 0.936 100 1 -2
3656.25 0.936 100 3 -1
3812.5 0.936 100 3 1
3968.75 0.936 100 3 0
4250 0.936 100 2 2
4406.25 0.936 100 1 2
4593.75 0.936 100 0 3
5000 0.936 100 0 3
4968.75 0.936 100 0 4
5218.75 0.936 100 0 5
5437.5 0.936 100 0 5
5625 0.936 100 0 6
5812.5 0.936 100 0 8
5968.75 0.936 100 0 9
6156.25 0.936 100 0 10
6343.75 0.936 100 0 12
6500 0.936 100 0 12
6656.25 0.936 100 0 13
6812.5 0.936 100 0 14
6968.75 0.936 89.41176471 0 19
And here's a log from a not-so-clean run. I can feel the car down on power (these are 4-th gear pulls) from knocking a bit, but how bad is this?
3562.5 0.897 100 0 0
3656.25 0.9165 100 4 -3
3718.75 0.9165 100 7 -4
3875 0.897 100 7 -3
3937.5 0.897 100 7 -3
4000 0.897 100 7 -3
4125 0.9165 100 7 -3
4218.75 0.9165 100 6 -1
4312.5 0.9165 100 6 -1
4468.75 0.9165 100 6 -1
4531.25 0.9165 100 5 -1
4593.75 0.9165 100 5 -1
4718.75 0.9165 100 5 0
4812.5 0.9165 100 5 0
4906.25 0.9165 100 4 1
5031.25 0.9165 100 5 0
5125 0.9165 100 5 0
5187.5 0.9165 100 4 1
5281.25 0.9165 100 4 1
5406.25 0.9165 100 4 2
5500 0.9165 100 3 3
5562.5 0.9165 100 3 4
5656.25 0.9165 100 3 4
5750 0.9165 100 3 5
5843.75 0.9165 100 2 5
5906.25 0.9165 100 2 6
6000 0.9165 100 2 7
6093.75 0.9165 100 2 8
6187.5 0.9165 100 1 8
6250 0.9165 100 1 8
6343.75 0.9165 100 1 8
6406.25 0.9165 100 0 10
6468.75 0.9165 100 0 11
6531.25 0.9165 100 0 11
6593.75 0.9165 100 0 12
6687.5 0.9165 100 0 13
6750 0.9165 100 0 14
6812.5 0.9165 100 0 14
6875 0.9165 100 0 15
6937.5 0.9165 100 0 15
7031.25 0.9165 100 0 15
Old Jan 26, 2007 | 02:49 PM
scheides's Avatar
EvoM Moderator
Hrm, now I am confused. So *sometimes* when I'm doing logging runs like above I get 6-8 counts of knock. Now here's the interesting part. I did some more logging on my home from the office today and simply drove like I normally do. It's a mix of stoplight driving around town in 2nd 3rd and 4th gear, with plenty of 2nd gear sprints and freeway driving doing runs through the gears on on-ramps and 4th gear pulls for misc passing/fooling around. It's 18 miles from work to home, and I never saw more than 2 counts of knock.
Old Jan 26, 2007 | 03:06 PM
EVOlution561's Avatar
switch to cooler range plug, thats what i did.
Old Jan 26, 2007 | 03:12 PM
scheides's Avatar
EvoM Moderator
What are you running? BPR8's or 9's?
scheides
For Sale - Cars For Sale
12
Sep 9, 2015 08:37 AM
scheides
19
Jun 14, 2009 06:17 PM
scheides
Sep 8, 2008 08:36 PM
scheides
10
Jul 14, 2008 10:58 AM
scheides
Mar 15, 2007 10:22 AM
