Mini wire-tuck on the evo
After drooling over kevin's 1G a little on friday night I decided to see what I could do to clean up the stock wire routing. I ran the wires that go across the intake manifold every which way and ended up settling on leaving about half running across the top front and all of the manifold-mounted sensors and TB wires run underneath and tucked.
The pile of little mounting clips and crap I removed:
Overall I'm kinda happy, but for this to really work I'd still need to extend:
-all 4 injector leads
-front o2 lead
-power steering lead
-ignition leads to left coil
Anyone know where I could get extension plugs/mini-harnesses to make this happen w/o cutting up my harness?
Here's a more stock-ish shot from about 2 years ago just for reference:
-front o2 lead
I am actually in process of doing this now. Granted my motor is out of the car, but I redid the ENTIRE harness, ie. exposing all the wires, and re-wrapping the entire harness. I have already extended the injector leads, the MAF wires, and a bunch of ther wires. I left all the leads that break out of the wiring harness free so that when i put it back together, I can route each one the way I choose, and once I am happy, wrap it again so it looks like it's OEM. I am also taking pictures of the entire process of my build so that I can do my own engine build thread, along with having pictures of the things like the wire tuck, all the new brackets and what not I am building as well.
Thanks for the nice comments guys!
did you wire tuck your spark plug cover? haha
Please show how you did your throttle cable.. I want to do this..
Also you might wanna look into getting the injector wires ran from under the intake manifold.
Looking good.
Looking good.
Can't run the injector wires and everything else I listed above w/o extending the wires, they come up about 8" short.
Yes, been that way since I got it, the car is tuned for it and it's worked perfectly as it is. I like it run this way better than the 'correct way' anyways, just fits better IMHO.
-scheides
FS[MidWest]: (MN) 2006 Evo9 SE - Tarmac Black - $21,999
scheides
For Sale - Cars For Sale
12
Sep 9, 2015 08:37 AM
scheides
19
Jun 14, 2009 06:17 PM
scheides
14
Jun 28, 2008 10:24 AM
scheides
24
Jan 26, 2007 03:12 PM
