Where to place AEM AIT Sensor??
Old Aug 14, 2007 | 09:20 PM
binh's Avatar
I did a search and had a hard time coming to a conclusion. Everyone has a different answer.
Where should the AIT sensor go?
Is it ok to put it in the path of the meth injection nozzle where it'll get sprayed all over?
Should I put it before the meth injection nozzle where it won't get soaked?
Or should it be placed in the intake tube where the cone filter is similar to a factory setup?
Someone help me out here...
Old Aug 14, 2007 | 11:08 PM
cpoevo's Avatar
Call Buschur Racing they will definitely know.
Old Aug 15, 2007 | 05:34 AM
SlowCar's Avatar
1 car i saw with aem and methanol injection that was done by IA Performance in tucson az had the IAT sensor behind the nozzle
IC -> IAT sensor -> atomizing nozzle/s -> throttle plate
Old Aug 15, 2007 | 07:27 AM
ryan0's Avatar
i would guess it depends on if you are using the AEM to compensate for intake temp.. in that case i'd assume yould want it after the spray so it could take a semi-accurate IAT reading..
but i think that most people dont adjust for iat.. so who cares.
Old Aug 15, 2007 | 07:39 AM
binh's Avatar
I care. I want my aem to adjust to big temperature swings from season to season.
Old Aug 15, 2007 | 07:48 AM
8thWonder's Avatar
David Buschur told me to mount the meth nozzle AFTER the AIT sensor. You DO NOT want the AIT sensor bathed in the meth.
Old Aug 15, 2007 | 08:00 AM
ryan0's Avatar
i guess if its for big swings.. before should be ok.. how much does meth lower the IAT?.. should only be a few degrees i think.
ryan0's Avatar
cause it will make it go bad?.. how long?.. and dont they cost like $20?
Old Aug 15, 2007 | 08:07 AM
binh's Avatar
By just looking at the AIT sensor it has a metal strip that measures the ait. I'm sure soaking it with fluids probably isn't a good idea.
Anyone ever hear of placing the AIT in the intake tube like a factory setup?
Old Aug 15, 2007 | 08:15 AM
8thWonder's Avatar
Yeah, I suppose over long periods of time. Exactly how long, I have no idea. They are pretty inexpensive comparative to other parts I guess.
Old Aug 15, 2007 | 08:47 AM
ryan0's Avatar
eh.. i see it like an o2 sensor.. to get good readings it will eventually go bad and its cheap..
EVIL-EVO-8
Jun 14, 2009 06:45 PM
90GSXDan
17
Nov 29, 2008 12:36 PM
EvoJoeIX
Mid-Atlantic Region
12
Aug 2, 2008 09:45 PM
Codeman17
Northwest Region
16
Apr 19, 2008 02:39 PM
Markley02
11
Feb 16, 2008 08:06 AM
