question about aquamist hfs-1 install
can you help me figure out the ebc issue now ,i put pics of it on page 2..i was thinkg the groundwire but not sure
It is more appropriate to interrupt the other pair of wire (green/white) - cutting the power to the EBC is a bit drastic.
Does the EBC green/white wire go to a solenoid valve in the engine bay?
yes the green and white go to the solenoid ,the white is the one i have split it connects to the black on the solenoind,with a test light they both show power there is a red also which is green on back of the greddy ,,then theres the red and black red to the battery and black to the ground ...when i had them pluged into the v8jb i was stuck on 12psi .....i disconected it and i got my boost back ..
Great, cut the white wire, connect the ECU side of the white wire to pin 11 of DDS3 and the solenoid side of the white wire to pin12 of the DDS3.
When the DDS3 is switch on, you should get full boost with the water spraying. Drop to wastegate when the DDS3 is switch off or the water flow is outside the WL and WH window.
ouch i didnt know that ,i only wanted to use the meth on like 26psi and drive around on low boost at 23psi,so maybe this wasnt the kit for me (
richard you have been a realy big help just wanted to say thank you for your time and patience
Wow...don't you guys ever sleep?
pbevo12, you can easily bypass the failsafe when you want to by installing a simple switch that connects pins 11 and 12. When you close the switch it will short circuit the failsafe. The danger is that you forget to flip the switch when you go back to high boost, in which case you wouldn't have your failsafe. It's really not a big deal and is what I plan to do, especially when I don't have the car yet tuned 100% for the kit but have it installed.
There is another DDS3 option most people have missed put.
Pin9/10 can enable a simple 2-way solenoid valve to increase you normal boost further when correct fluid flow is detected.
This facility will do exactly what you want - lifting the 23psi to 26 psi with meth. Read the user manual and let me know if you want to try this.
