question about aquamist hfs-1 install
Old Aug 27, 2007 | 04:18 AM
  #46
Richard L's Avatar
Originally Posted by EVO8LTW;
Wow...don't you guys ever sleep?
pbevo12, you can easily bypass the failsafe when you want to by installing a simple switch that connects pins 11 and 12. When you close the switch it will short circuit the failsafe. The danger is that you forget to flip the switch when you go back to high boost, in which case you wouldn't have your failsafe. It's really not a big deal and is what I plan to do, especially when I don't have the car yet tuned 100% for the kit but have it installed.
What are you doing at this hour of the morning? I forgot you are at EST.
Old Aug 27, 2007 | 04:31 AM
  #47
Richard L's Avatar
deleted
Old Aug 27, 2007 | 11:48 AM
  #48
pbevo12's Avatar
i would pretty much like to try anything so it will work the way i want it
and ya i ended up staying up all night working on my car and waiting for replys
Old Aug 27, 2007 | 04:19 PM
  #49
evilempire76's Avatar
Originally Posted by Richard L
Great, cut the white wire, connect the ECU side of the white wire to pin 11 of DDS3 and the solenoid side of the white wire to pin12 of the DDS3.
When the DDS3 is switch on, you should get full boost with the water spraying. Drop to wastegate when the DDS3 is switch off or the water flow is outside the WL and WH window.
Would this same principle work for my Apexi AVCR boost controller You're cutting the ground wire on the solenoid and splicing it into the DDS3 at pins 11 and 12?
Couldn't the OP just leave it all hooked up and aim the tube outside of the car to spray unsuspecting bystandards? J/K!
Old Aug 28, 2007 | 10:54 AM
  #50
pbevo12's Avatar
There is another DDS3 option most people have missed put.
Pin9/10 can enable a simple 2-way solenoid valve to increase you normal boost further when correct fluid flow is detected.
This facility will do exactly what you want - lifting the 23psi to 26 psi with meth. Read the user manual and let me know if you want to try this.
i wanna try this richard
Old Aug 28, 2007 | 02:23 PM
  #51
Richard L's Avatar
Yes, you can anyone of the two wire that goes to the solenoid valve. Doing the "cut and splice" inside the car is easier.
Old Aug 28, 2007 | 03:30 PM
  #52
pbevo12's Avatar
richard what solenoid valve do i need
can you get me one ?
Old Aug 29, 2007 | 12:00 PM
  #53
pbevo12's Avatar
Old Aug 29, 2007 | 12:23 PM
  #54
Richard L's Avatar
You need to get a 806-435 Boost control valve from any aquamist dealers. Dudical26 have a MAC valve available that will do the same thing.
Richard
Old Aug 29, 2007 | 12:29 PM
  #55
EVO8LTW's Avatar
My Blitz boost control solenoid has 3 wires -- white, blue and purple. I have no idea which is ground.
Old Aug 31, 2007 | 12:34 AM
  #56
BlueSi's Avatar
Yes. They are the same. One of the injetcor's pulse wire is Green. For ease of identification, I used that one.
The above comment was for a question asking if tapping into different injectors makes a difference.
My question:
I have a RX-7. It has a pair of primary injectors (1000cc) and a pair of secondary injectors (1600cc). Which should I tap into, or are there still no difference?
Thank you.
Old Aug 31, 2007 | 12:48 AM
  #57
Richard L's Avatar
One of those wires is common to the two solenoid coils. Splice the common wire.
Do you have a multimeter or a user manual you cam email me?
Old Aug 31, 2007 | 12:51 AM
  #58
Richard L's Avatar
My question:
Thank you.
The RX7 injector arrangement is very different to the EVO. It is a tricky one to get right. If you are triggering the HFS-1 below 25%, use the primary and if you go above 25% idc, use the secondary one. This will avoid the strange idc switching characteristics of the primary. 0 => 50% => 25% => 100%.
Old Aug 31, 2007 | 03:58 AM
  #59
EVO8LTW's Avatar
The manual is here:
http://www.team3s.com/Blitz%20SBC%20i-D%20manual.pdf
I've looked at it and it doesn't help. I had forgotten that it was a dual solenoid and was wondering why there were three wires instead of two. I'm going to take a guess that it's the white one that's common and clip that one to see if it cuts boost. If so, then I'll wire it to the DDS3. If not, I'll repair and clip another one. There are only 3 wires and I can't imagine it would hurt anything to just do trial and error so long as I'm careful not to overboost. I'll just set the controller very low to test all this.
Old Sep 2, 2007 | 01:08 PM
  #60
Richard L's Avatar
You are absolutely correct, the manual doe snot show any information on the pinout.
pbevo12
For Sale - Part Outs
37
Aug 22, 2010 11:15 PM
pbevo12
For Sale - Miscellaneous Automotive
17
Oct 1, 2008 07:41 AM
pbevo12
Mar 31, 2008 06:01 AM
pbevo12
27
Mar 24, 2008 05:06 PM
socalmr
Jun 23, 2007 08:08 PM
