Alky mixing question
Old Sep 21, 2007 | 08:51 AM
frycztech's Avatar
I searched and just kept getting different answers. I have a smc trunk mount kit and i am going to run Denatured Alcohol since that was what i got from searching. My question is do i put it in right out of the can or do i mix it with water? What would the mix be? 50/50?
Thanks
Stephen
Old Sep 21, 2007 | 10:23 AM
frycztech's Avatar
Anyone I want to prime the pump and finish hooking it up but i dont want to mess anything up.
Old Sep 21, 2007 | 10:25 AM
bigric09's Avatar
50 50 seems to be the correct answer since not all pumps say they will handle 100% alky.... you should be fine with 50 / 50. I poor mine into a large jug first to mix it, then poor it into the tank
xiaoni420's Avatar
It's whatever mixture you want to go with. I am running 100% methanol, which I love, and there are others out there running a 50/50 mix. It is all up to you on what you want to go with. Whatever you choose to do though, you have to keep the same mix all the time.
Old Sep 21, 2007 | 10:27 AM
xiaoni420's Avatar
Yeah, I'm not too sure about the quality of your particular pump. Some may not be made to handle 100% meth/alcohol. I would check with whomever you bought it from, the specs of the pump/kit you have.
Old Sep 21, 2007 | 10:29 AM
bigric09's Avatar
Originally Posted by xiaoni420
Yeah, I'm not too sure about the quality of your particular pump. Some may not be made to handle 100% meth/alcohol. I would check with whoever you bought it from the specs of the pump/kit you got.
i have the SMC kit... im sure it would handle 100% but for how long i guess is the question. Some kits say they dont recommend it, but then you ask the people selling them and they say they have no problems.... i just stick with 50/50 because thats what im tuning for
Old Sep 21, 2007 | 10:36 AM
frycztech's Avatar
So half denatured alcohol half water?
Old Sep 21, 2007 | 10:39 AM
bigric09's Avatar
i actually use something different then denatured alcohol... i use the product called HEET. its in a yellow bottle. they sell it at wal-mart, autozone, its pretty inexpensive and easy to find.
Old Sep 21, 2007 | 10:44 AM
frycztech's Avatar
I already bought the Denatured alky so should i just mix it with water? I dont want anything to get messed up. I dont dd the car so if i go 100% would that be bad sitting there?
Old Sep 21, 2007 | 10:45 AM
bigric09's Avatar
nope... should be just fine
Old Sep 21, 2007 | 10:47 AM
frycztech's Avatar
Ok so 100% is alright thanks guys just wanted to make sure!
Old Sep 21, 2007 | 10:51 AM
JordanS4's Avatar
yes I run 100% denatured all day and no failures to date after 5 months.
Old Sep 21, 2007 | 10:54 AM
staatz's Avatar
100% meth, its cheap and easy to get. But mixing it 50/50 is fine.
Old Feb 29, 2008 | 11:48 PM
TurboTodd's Avatar
Meth tune
You have to inject the percentage of Alky which you were tuned for. If you add to the percentage of Alky you will run richer and probably lose power. Todd
Old Mar 24, 2008 | 12:11 PM
20gmr's Avatar
i have an smc kit and have been using 100 percent den. alky for a few months and i got the kit used. the previous owner also used straight denatured. i understand the theory i just can't put water in my engine idk seams like a bad idea
elim0
Jun 23, 2015 06:07 PM
Vigman
Jan 20, 2011 11:55 AM
foxracingx25
Oct 3, 2010 08:35 PM
bbyevo8u
24
Apr 29, 2009 05:08 PM
mikiblueeyes
10
Nov 20, 2005 06:14 AM
