DDS3 adjusting?
Old Oct 3, 2007 | 04:21 AM
aboh6leenz's Avatar
DDS3 adjusting?
I have a hsf-1 system and am now on making the dds3 gauge function correctly.
1. Do I have to adjust the trip adjustment first in the junction box? I think we've gotten it to about 10psi of boost to turn on but depends on the gears. It is set to PWM right now.
2. If I have it in MPS it goes off constantly. Is this correct since I spliced into pin #2 on the ecu which is injector 3.
3. If I don't have the dds3 gauge setup correctly will it run wastegate boost? Because it is right now.
4. I'm not quite sure how to setup the gauge I've read the instructions in both guides. Do I essentially have to go out and drive adjust drive adjust... Someone needs to break it down for me
thanks.
Originally Posted by zl1560
Is there any way to make the low level float only turn on the low level light and not turn off the system when tripped? I just want to use it as a low level indicator and not a failsafe. Thanks.
oh and anyone figure this out? I mounted my low level float a little high because I thought it would only trigger the light and not failsafe.
Old Oct 3, 2007 | 01:55 PM
aboh6leenz's Avatar
bump
Old Oct 3, 2007 | 02:21 PM
Richard L's Avatar
thanks.
0. Decide if you want to trip by PWM or MPS. PWM is easier to correct your METHANOL equipped fual map since you only need to modify the cells that go above a certain %.
Answers to your questions:
1. The trip adjust is the most important one to set. If you are not sure, set it at 12o'clock. about 42% IDC.
2. For MFS trigger, you must connect it to the MAP sensor before changing the link to MPS orr it will spray constantly.
3. If you don't set the SC, WL and WH, it wil most probably switch to wastegate pressure intermittently.
4. Failsafe adjustment steps (not spliced yet):
a. Take the car for a drive
b. Ask your passenger to set the SC to display ~5 bar.
c. Advance the WH fully CW (clockwise).
d. Advance the WL CW (clockwise) until the "B" led no longer comes on. Turn back 2-3 clicks.
e. Adjust the WH CCW until the "B" led no longer comes on, advnce CW 2-3 clicks.
You have now successfully set the "failsafe" window. Cut and Splice the OE BCV wire between pin 11 and pin 12. ECU side to pin 11 and BCV side to pin12.
You can do this on the ECU side.
Old Oct 3, 2007 | 02:44 PM
aboh6leenz's Avatar
ty
Is it okay that I already spliced into it before doing all this stuff?
Also for the red and blue wire going to the solenoid valve. which color is on 1 & 2 or does it matter?
Old Oct 3, 2007 | 02:51 PM
Richard L's Avatar
It will be difficult to calibrate the WL and WH if your boost keep going up and down.
For the time being, link pin11 and pin12. ONLY safe to do so
Old Oct 4, 2007 | 03:13 AM
aboh6leenz's Avatar
so in between every step i should trigger the dds3 gauge correct? Also in the end the "B" led should be always on right? I also can't get it to show less then 6 bars.
Thanks
KevinD
125
Mar 31, 2008 06:50 AM
dubbleugly01
24
Nov 7, 2007 07:29 PM
BOOSTEZ
Oct 19, 2007 08:05 PM
joah1660
17
Sep 19, 2007 01:19 AM
aresix6
46
Jun 6, 2007 02:42 PM
