Water/Alcohol on a Daily Driver?
you can, you need 2 maps, and ability to switch between them, say with ecuflash reflash/
you also need a way to disable your water/meth system, and bypass failsafe so that your boost is not limited to wastegate.
P.S. I dont belive you can run water meth when autox, which you may know so you would also have to drain and empty your water.meth system, pita
ROCK ON
ROCK ON
I'm sure there is some thread out there and on some page this question is answered. I just dont have a ton of time to read though everything being I'm in the Military and work an insane amount of hours (mostly in the field) getting ready for deployment.
Current mods:
Built engine consisting of:
crower rods
arias pistons
dual vale springs and retainers
arp head studs
Modifications:
GSC 264/272 cams
hks Downpipe
Cat Delete
RMR cat back
hallman MBC
HKS intake
ACT Street Clutch (30k miles on it normal driving)
FP- Green turbo
HKS DLI 2 Ignition
Precision 880cc Injectors
AMS IC and Piping
Is it possiable to tune a car so it can run on water/alco spray and run with out it? This car is a daily driver as you know, but I plan to do some AutoX and Track days. (sometime in the future if I get time off) Is there a way to put this system in the car and only run it when I need like when I race with out having to change the tune? Let me know your ideas on this.
Thanks!
Current mods:
crower rods
arias pistons
arp head studs
Modifications:
GSC 264/272 cams
hks Downpipe
Cat Delete
RMR cat back
hallman MBC
HKS intake
FP- Green turbo
HKS DLI 2 Ignition
AMS IC and Piping
Thanks!
richardjh
120
Oct 6, 2017 08:58 AM
jason42003
Jan 20, 2014 12:34 PM
