Best Pump????
Old Nov 19, 2007 | 06:12 AM
EvoTech's Avatar
Best Pump????
OK. I am done with SMC and the crap flojet pumps on their kits. I have been through 3 of them and I could care less if they are warrentied or not. I am not putting another one back on my car. With that said. What do you think is the best possible replacement that I can still use with the SMC controller? Any way of using a stock fuel pump?
Old Nov 19, 2007 | 07:54 AM
staatz's Avatar
Coolingmist pump.=D
Old Dec 7, 2007 | 03:09 PM
Ultimate CC's Avatar
If you want a snow pump just let me know ed...
Old Dec 7, 2007 | 03:10 PM
06rs_power's Avatar
when i had my meth setup on my old 8 i had the coolingmist pump, it worked great
Old Dec 28, 2007 | 01:08 PM
Evotech8's Avatar
Sorry to bring this up again, but where you guys able to directly swap out the SMC kit flojet pump with a shurflo/coolingmist pump without any issues?
After two years my flojet pump is loosing pressure and I'm looking into a better replacement pump that works with the smc controller.
thx!
Old Dec 28, 2007 | 01:11 PM
sleet's Avatar
What happened with your SMC pump? I am running this kit as well and i'm on my second pump because the first one was leaking..
Old Dec 29, 2007 | 12:30 AM
Evotech8's Avatar
My smc flojet pump has been slowly loosing pressure over time, but not leaking.
It used to be around 100psi, but now its dropped down to 80psi. I had to compensate by switching the smc v2 controller dip switch to the highest output setting to keep the pressure at 100psi.
This tells me the pump seals are probably worn out and need to be replaced soon.
Rather than get another flojet pump, i'm looking for a alternative durable pump that will work with the smc controller?
Has anyone successfully done this??
Old Dec 29, 2007 | 05:47 AM
SlowCar's Avatar
thx!
a shurflo pump ( 3 different motor stack 60w, 100w and 150w) will draw a lot more current than a puny flojet...check to see if the controller can handle it. You dont want to fix one thing and mess up another
Old Dec 29, 2007 | 03:42 PM
Evotech8's Avatar
Thanks for the info SlowCar.
I read on turbo buick forum smc tried using a 100w shurflo pump in the past but gave up on it due its larger size/mounting and some wiring issues. The question is then can the smc controller still handle the higher current?
I guess the only way to find out a shurflo pump can safely work with the controller is to call smc.
Old Dec 29, 2007 | 03:49 PM
SlowCar's Avatar
yep, call steve@smc. The shurflo will draw as much as 10amps... Also ask him about reliability issues too on high load operations.
Old Jan 1, 2008 | 12:11 PM
Richard L's Avatar
The Flojet pump draws 4.5 amps max.
Cobrajetguy
Jan 26, 2013 05:05 AM
L@n3vo9rs
Nov 29, 2011 05:53 PM
4WS Tuning
Sep 3, 2007 07:46 AM
EvoTech
10
Feb 16, 2007 03:30 AM
