Devils Own Meth Kit
Old Dec 8, 2007 | 09:22 AM
DTM2188's Avatar
Devils Own Meth Kit
Does anyone run a Devils Own Meth Injection kit? I see a lot of other brands being used on here by members, but have yet to see Devils Own. When I had my Cobalt, Devils Own and Snow were the two biggest brands used, so I was curious to see if there was a reason that Devils Own wasn't too popular here.
Old Dec 8, 2007 | 12:56 PM
Dapper Dan's Avatar
im pretty sure the devilsown kit is for map based cars.....
Old Dec 11, 2007 | 08:55 PM
Ultimate CC's Avatar
Not really sure, don't know too much about them...but if your looking for snow just let me know :0
Old Jan 28, 2008 | 01:17 PM
Rocket468's Avatar
We just have not actively pushed our products here. So many forums out there its hard to keep up. Kinda stretched thin, We are always looking for people interested in being dealers for us.
On Evos our controller should be hooked up to the evo MAF sensor.
Old Mar 17, 2008 | 05:26 PM
SILVER9's Avatar
i just have a devils own meth kit install in my car and it works fine
Old May 17, 2008 | 07:58 PM
GTijoejoe's Avatar
Devils own will support both map and maf based systems. You can choose.
Old May 17, 2008 | 09:13 PM
Ph3n1x's Avatar
Dont have their kit but have some components. Specifically their nozzles are very good quality.
Old May 21, 2008 | 07:41 PM
blackDSM91's Avatar
How is the install on these kits?
Old May 4, 2010 | 11:10 AM
LookThatsMe's Avatar
I just installed mine last night but I'm having issues. Not devilsown fault just something I did wrong because when I connect power the pump stays on the whole time regardless if the pressure switch sees boost or not
Old May 8, 2010 | 04:00 PM
karlevo8's Avatar
hi have you wired up the relay as per the instructions ?have you got ignition live and permanent live around wrong way! if you dont get it sorted have a butchers on devilsown site decent forum plenty of help on there
Old May 12, 2010 | 08:51 PM
Yea I wired it up to the relay. As far as the ignition 12v I have it ran to the cig power wire. I uave the pump and tank in the trunk and bought my own hose and ran it along the side of the car. Took the fender off and you see the wiring harness that come from the door panel made a little hole in it and ran the tube up the fender well into the engine bay.
Old May 13, 2010 | 09:28 AM
karlevo8's Avatar
did you solve the problem you had in the end
Old May 13, 2010 | 12:22 PM
Yea the pressure switch was bad. I bought it used of my friend for 300 cause he blew his motor and bought a fully built to run race gas and high boost... I ordered a new pressure switch which cost 37 shipped no big deal and it all works great now... Debating if I wanna sell it if I will I'll be asking 220 shipped... Might go fully built with a bigger turbo
boostaddikt
18
Oct 21, 2014 06:51 PM
dadsgts
Sep 18, 2011 09:54 PM
deathangel1812
Jul 2, 2009 02:09 PM
NJ_EveOhVIII
Jun 19, 2008 01:55 AM
