Mounting tank in engine bay running 100% meth??
Old Sep 14, 2008 | 11:36 AM
djsgtrip's Avatar
Im installing a snow stage 2 meth kit. I have an APS cold air intake and was going to use the intercooler sprayer reservior that came with it as the meth tank. It's basically located where the intake would be otherwise. I plan on running 100% meth. What do u guys think about that? Snow recommends running 50/50 cuz anything past that is considered flammable. Would the engine heat be a little too high and possibly ignite the meth?? I'm inclined to believe that it should be safe. But I wanted to see what you guys think or anybody w/ experience with it mounted in the engine bay?? Thanks for looking.
Old Sep 14, 2008 | 11:44 AM
burgers22's Avatar
I have a similar inquiry, but want to use the stock intercooler water tank in the engine bay.
MB
Old Sep 23, 2008 | 08:31 AM
wreckleford's Avatar
I know many people running 100% meth from the stock intercooler tank. Nobody has had problems, but I am interested to hear what others think.
Old Sep 23, 2008 | 08:38 AM
cfdfireman1's Avatar
It's pretty safe just don't splash the stuff around with the car running.
Autoignition Temperature: 464 deg C ( 867.20 deg F)
Flash Point: 11 deg C ( 51.80 deg F)
Decomposition Temperature:Not available.
NFPA Rating: (estimated) Health: 1; Flammability: 3; Reactivity: 0
Explosion Limits, Lower:6.0 vol %
Upper: 36.00 vol %
Old Sep 25, 2008 | 09:58 PM
djsgtrip's Avatar
nice info!! thanks. I ended up mounting it in the engine bay. So far..so good.
Old Sep 26, 2008 | 10:09 AM
That's where mine is, better than the truck which is essentially the passenger compartment.
Old Sep 26, 2008 | 04:12 PM
Jack_of_Trades's Avatar
I run 100% meth in the stock intercooler sprayer tank. No issues. The stock ICS tank is 95% in the wheel well though, so its not the same as mounting it in the actual engine compartment.
tonyboy
Feb 28, 2010 05:08 PM
evo9ben
Feb 18, 2009 09:59 AM
vaflyboi757
19
Feb 2, 2009 07:55 AM
Celica2EVO
Feb 4, 2008 05:58 PM
EvilBlueEvo8
Oct 19, 2006 06:49 PM
