Aquamist DDS3 V.10 Install Pics
Old Dec 13, 2008 | 10:21 PM
  #31
daisaw1219's Avatar
any more info on the power box. I always wanted to make a box where i can tap power from for all my gauges and wideband becasue i am tired of splicing into different wires. It seems like a good idea, ive actually seen a fuse block type setup which was selling at summit for $150 which is similar but i dont think its worth it.
Old Dec 15, 2008 | 05:49 AM
  #32
dudical26's Avatar
This power box cost me about $5 to build....so way less than the $150 summit wants.
It does not have a fuse in the power box itself but there is a fuse just before the power goes into the box. If you wanted you could get one of these fuses
http://www.jtekmachinery.com/p-5468-daito-hp32.aspx
And a solder on fuse holder for circuit boards. Then you could have the fuse inside the box if you really wanted.
Here are the screw terminals
http://www.winford.com/products/stb.php
All you do is just lay down a big bead of solder along each side of the board which ties all the pins on the screw down terminals together. 1 side for ground and one for power. Then just tap power and ground somewhere and supply to the top of each "rail"
Old Dec 31, 2008 | 09:23 AM
  #33
Slick-IX's Avatar
oh man ive been off the meth section for a while... i didnt even know v10 was out lol
looking good dub, i got my flow sensor on the same spot
dudical26
73
May 5, 2026 05:15 AM
dudical26
76
Apr 22, 2008 05:10 PM
dudical26
21
Jan 25, 2008 02:19 PM
dudical26
73
Sep 24, 2007 01:43 PM
dudical26
32
Sep 6, 2007 07:37 AM
