Meth failsafe ????????????
Old Jan 5, 2009 | 11:56 PM
evo9ben's Avatar
hi should i install a meth failsafe what do you guys think???? or do you think ill be fine if i keep meth in the tank and make sure it never runs out ?
Old Jan 6, 2009 | 02:02 PM
SICK9's Avatar
A Failsafe is a must have if you are running meth.
If you do not install one, you are asking for big trouble.
The failsafe is for when the pump stops working.
It will cut the boost to WG pressure to save your engine.
I would also get a low level indicator for the fluid level.
That will tell you if it's low.
2 seperate things.
Old Jan 6, 2009 | 05:04 PM
aqmist's Avatar
A good failsafe mechanism that can monitor flow and supply level and take action if necessary should basically be a requirement if you tune for the water/methanol being injected. If you are just injecting water/methanol on top of a safe or factory tune that's not dependent on the water/methanol then you should be OK..........but IMO thats a waste if whats being attempted to be done with the water/methanol injection is more then just cooling the intake air charge down.
There's a stickied thread in this section that helps to explain failsafes and why to use.........if tune for the W/A get a failsafe that you trust will do what you want it to do.
Old Jan 13, 2009 | 03:31 AM
SlowCar's Avatar
you should
things to look for in a failsafe
-trigger when underflow(clogged nozzle, kinked tubing, pump worn, leak pre flow sensor...)
-trigger when overflow(leak post flow sensor......nozzle popped off...)
-trigger when low level sensor in injectant tanks are activated
look for a failsafe system that will handle all the above - an excellent choice is the Aquamist DDS3
you know the saying - you want to play, you got to pay. pay now and pay less, ~$300 for a failsafe vs. a blown motor.
Old Jan 13, 2009 | 04:06 AM
Ultimate CC's Avatar
a failsafe is a cheap investment when you look at the big picture...
Old Jan 13, 2009 | 09:59 AM
dudical26's Avatar
What happened to Abner's post ---
Man this forum is squeaky clean, you can't even poke fun of someone.
Old Jan 16, 2009 | 01:20 PM
Labonte MotorSports's Avatar
It all depends on how you are going to tune your engine with meth. A 50/50 mix will drop AFR from 11.5 to 11.0. You can lean back out to 11.5 and have a safe tune that will add some power. If you are going to lean out engine more then 11.5, then Yes a Fail Safe is a must.
Here is a link to our current fail safe product offerings.
http://www.labontemotorsports.com/st...onitoring.html
For Evos our IFS-30C works very well. Keeps you at WG boost until meth flow is above set point, no meth = no high boost. Also keeps you at WG if you blow a fuse or a wire comes loose on your meth system.
Old Feb 17, 2009 | 03:11 PM
spyderx's Avatar
anyone know if there's a failsafe system for SMC v2.0? recommendation?
Are there generic failsafe that I can add onto this?
thanks guys! my used VIII came w/ SMC but w/o any failsafe. I want this to kick in at certain boost level based on a single ECU flash and I can toggle between Hi/Lo boost settings...thx
Old Feb 18, 2009 | 07:23 AM
gear head's Avatar
^DDS3 triggering Tephra Map switching or the wastegate solonoid will work just fine.
Old Feb 18, 2009 | 09:59 AM
Richard L's Avatar
The DDS3 will work well. The gauge button will enable you to run high or low boost. Need to contact me to supply the -4AN fittings.
JeyEvo
Dec 8, 2014 10:30 AM
anthonyrb98
Sep 30, 2011 07:13 PM
kirkklau
18
Oct 24, 2008 06:46 AM
SexyEvo8
Jun 22, 2008 09:25 PM
smokedmustang
46
Feb 6, 2007 01:24 PM
