2-Step with Meth
2-Step with Meth
Hey Guys,
I tried searching and didn't find anything. I'm running 50/50 meth. My question is on 2-step. Right now I'm building about 10 psi, and I have my system to start spraying @ 8psi. Are there any harmful side-effects from spraying during 2-step, or should I raise the start point start spraying to about 12psi?
I would raise it above 2-step boost without a doubt.
Couple reasons -
2-step if fuel cut, which means if you spray meth you are running the engine on 100%meth during the fuel cut revolutions. Potentially dangerous
Also, if you spray a lot of meth, might bog the engine once you come of the two step.
Couple reasons -
Couple reasons -
Couple reasons -
Because I have the same setup and my meth does not spray in 2step mode. My meth starts when the turbo starts spooling but not on the 2step or at 20 psi and up.
Sorry to bring this post back up but i was a little curious if anyone was using NLTS with their meth injection?
mt057
11
Apr 24, 2011 11:28 AM
Mirage2.0
11
Mar 16, 2008 06:50 PM
