Project X - Water/Meth Install!
Old Sep 4, 2009 | 08:07 PM
tephra's Avatar
Hi Guys,
Righty this will be a work log hopefully
Feel free to chime in with ideas/suggestions
Proposed Mounting position:
Fabricated bracket:
This is 4mm 5005 aluminium. I could have gone for 3mm or maybe even 2 mm, it doesn't flex at all...
Gauge Mounting/Setup:
Cheers
D.
Attached Thumbnails Project X - Water/Meth Install!-evo_x_meth_install_1.jpg
Old Sep 4, 2009 | 08:54 PM
Benja's Avatar
Any idea of the weight that will be placed on the board?
If you can get a weight figure, and approx G-forces then you can calculate the flex.
If it were me, i'd screw 2-3 thin cuts of particle board ~5cm wide, just under the width of the board onto the rear of it to give it strength.
Old Sep 4, 2009 | 08:58 PM
Import Junky's Avatar
can you use strips of aluminum in a "cross" shape on the back of your sheet to re-enforce it?
Old Sep 4, 2009 | 10:34 PM
tephra's Avatar
weight will be:
possibly 2x 5QT tank - 12kg total
1 pump - 3kg total
So I reckon 15kg total.
Normally driving you would not exceed 1G, however in an accident you might go WAY above that.
Yeah I see what you mean, if you can have something coming up from the bottom that will help brace it
I have contacted a local aluminum fabber, i will see what he thinks too!
possibly
Old Sep 5, 2009 | 05:05 AM
Richard L's Avatar
Using an trimmed angle iron might work.
Old Sep 5, 2009 | 06:27 AM
tephra's Avatar
ahh yeah...
i was thinking something similar..
even just a thicker brace rather than angle... might see what the guy has lying around...
i was thinking some 7075 grade hehe
Old Sep 5, 2009 | 07:20 AM
tephra's Avatar
actually thinking about it:
i think i will try and get the bottom edge bent towards the rear of the car... that should provide the "angle" and add a lot of strength...
Old Sep 5, 2009 | 08:04 AM
mt057's Avatar
Richard has this posted in his hfs-5 q&a post. Here is a link...https://www.evolutionm.net/forums/wa...icial-q-3.html.
Post #32
Old Sep 5, 2009 | 06:13 PM
tephra's Avatar
yeh but its requires a different setup on the X
Old Sep 7, 2009 | 07:52 PM
tephra's Avatar
ok guys I need some advice:
USP 6QT = 41 cm high
USP 5QT = 35 cm high
Vertical space in the boot is about 47cm
Concerning refills do you think going the 5QT is best? Obviously I will still need a LONG hose..
Or do you think go for 6QT given that I have to use a hose anyways..
I was going to go for 2 tanks side-by-side anyways, so its either 10QT or 12QT total...
Old Sep 12, 2009 | 03:40 AM
tephra's Avatar
I have decided on the 5QT... It will just be easier to deal with when refilling
Been talking to Jeff@Howerton about some extra bits'n'bobs to hook up 2 tanks... Should have that soon with some pictures
Old Sep 13, 2009 | 03:08 AM
tephra's Avatar
lol - I changed my mind to the 6QT... I also ordered a cheap pump to make refilling a LOT easier
ok all coming together now
BIG thanks to Jon@HBSpeed for collecting everything and shipping to me in Oz
Old Sep 13, 2009 | 09:42 AM
Richard L's Avatar
It appears that you are racing a lot, what is the average duration of each race? I was trying to estimate how long will a 12 quart supply last.
Old Sep 13, 2009 | 03:59 PM
tephra's Avatar
well i probably wont race this car... too expensive lol
but if I did its about 10 mins a session...
Old Sep 13, 2009 | 04:15 PM
Richard L's Avatar
10 Mins is quite a long race.
