Jet location for evo X?
Old Sep 17, 2009 | 02:26 AM
tephra's Avatar
Hi Guys,
ok so I think I will run 2 jets, however I am not sure where to put them.
What do you think?
Realistically I can only tap into the #10 pipe there...
Cheers
D.
Old Sep 17, 2009 | 10:51 AM
Richard L's Avatar
no. 10 is a good place.
Old Sep 17, 2009 | 11:46 AM
scheides's Avatar
EvoM Moderator
#7 is not metal eh?....that's too bad Aftermarket piping an option?
I'd say right at the TB in #7 near the TB, as well as right near the FMIC outlet, somewhere on pipe #10...be sure to mount it in a fashion that won't get caught by road debris or anything, from the top or something.
If you gotta stick with stock piping, I say put one on either end of pipe#10.
Old Sep 17, 2009 | 04:24 PM
tephra's Avatar
Yeh I have been looking at an aftermarket LICP... but don't really want to spend the $$$'s
So I was thinking of two 0.8mm jets, thoughts?
Given the run to the BOV return is so LONG I should really have any problems with mist (or whatever) getting to the turbo should I?
Old Sep 17, 2009 | 07:53 PM
tephra's Avatar
Actually thinking about it I could cut #7 and insert a short metal pipe (with Tclamps) and then tap that.
Is having a jet closer to the TB much better?
ie just before the bend on #7 VS at the end of #10
Old Sep 17, 2009 | 08:38 PM
scheides's Avatar
EvoM Moderator
Not a bad plan! Yes, closer = more octane, farther away = better cooling of intake charge
Doing one close to the TB and one at the side of #10 close to FMIC outlet is ideal IMHO.
Old Sep 17, 2009 | 10:10 PM
tephra's Avatar
ok i will see if I can get some correct sized pipe
quick Q about jet sizes:
is it NOT advisable to use different sized jets?
I am still not sure if I should go for:
2x 0.6mm
or
2x 0.8mm
or
1x 0.8mm + 1x 0.6mm
If someone were to say jet size makes frack all difference then I will just get an extra 0.8mm (to save money!)
5LEEPERISAH23I
Jan 15, 2016 06:18 AM
Dragking2189
Jan 16, 2011 01:26 AM
tephra
11
Apr 9, 2010 10:07 PM
EVO8904
Dec 30, 2006 03:46 PM
EvoDan2004
Nov 8, 2005 08:23 PM
