Aquamist HFS-3 on a B5 S4
Old Sep 27, 2010 | 09:24 PM
scheides's Avatar
EvoM Moderator
Heya, just thought I'd share an install I just did on an OWWWDEE!
John dropped off his beautiful B5 S4 at my place on Friday night. I laid the smack down that night till about 3am, worked most of the day Saturday, then spent a few hours sunday and tonight troubleshooting some issues and buttoning this beast up.
Bi-pipes all tapped and sealed:
Tank drilled and starting sealing process:
Tank mount roughed in:
Fluid tubing and pump control/power wrapped in fancy wiring loom/protective sheath, then run nicely through wiring channels:
Routed and mounted flow sensor under ECU:
then cleaned up wiring:
and note the standard 'scheides' gaugepod, LOL. 2 zip ties and the dash vent! Sits nice and perfect
What's back here?
Oh, nothing.....
I must say, the new HFS-3 kit is an absolute leap above the HFS-1 in terms of fit and finish. I'm very very happy with how the whole kit turned out, and really even more excited to think about putting one on my Evo X
2.5 gallon main tank with .25 quart surge tank anyone? I think so...
Old Sep 28, 2010 | 07:17 AM
scheides's Avatar
EvoM Moderator
Quick pic of the car, very nice dark blue color with some 18" S8 (?) rims.
The setup is kinda silly right now though, Aquamist, full catless dual exhaust ($$$!), K04 turbos, ER bar&plate intercoolers with carbon fiber shrouds, bilstein coilovers, etc, but the car is on the stock tune/injectors! God I hate the stupid chipped-only tuning design, so silly...the thing only runs 9psi. 9! This setup is ready for 25
Old Sep 28, 2010 | 03:58 PM
Richard L's Avatar
Very nice install on a very fast car.
Are you going to turn up the boost to 25psi soon?
Old Sep 28, 2010 | 06:49 PM
scheides's Avatar
EvoM Moderator
Yup, these german cars need chips, not tunes you know, wish I could talk him into doing maestro and just tuning it himself or locally
He's going with EPL software though, best in the biz as far as I'm concerned. Shouldn't be to terribly long, I'll report back
Old Nov 1, 2010 | 08:54 AM
jmtx86's Avatar
I miss my s4 . Had the same color as well. Good luck with her
Old Nov 1, 2010 | 08:58 AM
jmtx86's Avatar
Ps your ko3s will not like 25psi, mine didn't also I'd just get a giac flash and use lemmi to tweak it and wb to!
I have a open elemnent filter kit, red Samco tbb, obdII cable, giac cable and a couple other things if you're looking for parts
scheides
124
Feb 6, 2014 02:15 PM
scheides
Jun 19, 2009 05:50 AM
scheides
Nov 20, 2008 05:49 PM
scheides
14
Jun 28, 2008 10:24 AM
scheides
101
Mar 30, 2008 06:50 PM
