Las Vegas Evo's
Originally Posted by spinme4fun
I think for one - corey should get the nod on one of those spots. He puts alot of time into peoples cars out here ( me being one ) and has alot into his car - no way alex your car should be beating his imo . Its not even close from what i hear and thats just wrong
hook corey up imo
my 2 cents lee
hook corey up imo
my 2 cents lee
Originally Posted by gonzo
Its not that we think the SAFC is superior, its just what happened with the guys who got flashed that got us thinking twice about it. Evilevovegas baseline dyno was 282 awhp on a flash and mine was 296 with an SAFC using Buschur settings. He has a 272 intake cam, FMIC, and test pipe over me. We both use all Buschur products. My 100 octane tune was 330 @ 24 psi while Corey's was 327 @ 27 psi. Thats what got us thinking. Maybe the car didn't take the tune or something was botched in the process of tuning.
We suggested that Corey go ahead and get his reflash worked out to see what it can do over the SAFC with our own eyes.
We have a Dyno Day on Nov 30 and Dec 1. If you can make it out then, that would be perfect as we have close to 10 EVOs getting tuned on HPH mustang dyno the majority with SAFC II. Same setup as Dave's MD. Heartbreak dyno if you will.
I will take you up on that offer. I want that second slot. I'd be willing to take one for the team so to speak.
Back when I first approached David about the idea of incorporating the reflash in with the Buschur Staged packages I canassure you that there was no way it would happen unless there was results to verify that the reflaszh had an advantage over the SAFC. Even way back then in the infancy of my days as a reflash tuner the reflash was able to make significant improvements over a SAFC in the power band, tq and smothness. Of course, I owe a lot of what I know about tuning these evos to the tips and tuning recomendations shared with me by David in the course of working on those original base flashes and in the course of many subsequent dyno tuning sessions over the past two years.
Over time my skills have improved and lately I have been finding ways to make huge power on pump gas. The stock ecu is a most complicated device and the longer you spend working with it the more you understand about how it works and how to make more power.
As a result of the significant advantages of the reflash it was adopted as the PRIMARY tuning method for the Buschur Staged 1 -4 upgrades for the Evo.
Not only has the reflash proven on multiple occassions to be superior to a SAFC on the old Buschur Dyno Jet dyno it has continued to be superior on the new Buschur Mustang dyno. At this point, we are not talking about one or two examples - we are talking about dozens and dozens. In fact, David has posted on more than several occassions that in Stages 1 - 4 the reflash can achieve results almost as good as the AEM EMS.
BR350 serial # 1 with on board ecu controlled boost control went 12.7 and that package maintains a original factory cat.
When David informed me of the situation there in Las Vegas, I decided to take some action to correct the misconception.
To set forth in a nut shell why the SAFC can not produce as good a result as a reflash we need only examine the nature of the SAFC itself.
The manner in whcih you tune an engine with a SAFC is by manipulating the MAF sensor signal to trick the ecu into thinking there is less load.
A MAF sesnor is a device which measures load on the engine by metering the air flow.
By electrically reducing the level of the MAF signal (OR increasing it) - the SAFC can make crude A/F ratio corections
As the stock EVO fuel mapping - (BOTH MAPS) - is overly rich - almost all SAFC corrections are NEGATIVE adjustments
The problem is that when you reduce the LOAD reference signal to the ecu the result is that you make a simultaneous FUEL AND IGNITION mapping change. The un-intended result of tricking the ecu to see a lower load is that it interprests this reuced load by running MORE ignition advance.
With less load you have less cylinder pressure and you can get away with signficantly greater ignition advance
The stock ecu maps have significantly greater advance numbers at LOAD ranges 10 - 12 % lower than stock boost levels. The result of a - 10% SAFC setting is not only a leaner A?F ratio but also much more timing.
As the stock factory ignition timing is already really more than most modified Evos can tolerate on 91 octane fuel without experiencing knock, when you add more timing the result is more knock.
The ecu quickly reacts by starting to pull ignition timing a little bit with every pull. After a few short minutes you wind up with a ignition curve which is rough, unsmooth and will have zero ignition advance or in some cases negative timing.
If any of you guys running a SFAC doubt me on this - take any generic OBDII scan tool and log your ignition timing which the ecu is running. Do a nice 3rd of 4th gear pull from say 3,400 to red line. As I like to say it is what it is.
retarded ignition timing and lean a/f = high egt - lots of engine mechanical stress through increased knock activity and thermal load and reduced tq
There is no doubt you can sqeeze out some power with a SAFC tuned evo on the dyno, however the fact remains that it is a really crude and ineffective way of doing so,
Way back in the day - when I was the first Evo 8 to run 11's in April of 2003, I was using a SAFC and qucikly discovered that by using a emanage and having independant control over ignition timing I was qucikly able to smooth out my ower band and add huge gains in TQ
These discoveries are all of course ancient history and yet there is a whole grroup of people who swear by SAFC
With a reflash, A/F corrections have NO effect on the ignition maping
The A/F for both the high and low octane maps are set directly as is the ignition mapping
Thus the tuner can set exactly the A/F and timing that is desired
By being able to independantly and seperatly adjust these very important parameters a really smooth and knock free tune can be achived
As for Dyno Flash ALL my custom tuned road tunes are set up to run with a total absense of ANY ecu induced knock ignition adjustments. This means that the ignition maping is set up to run with a almost total absence of any detonation with the fuel the customer is using at the time of the tune. This is done for two reasons, #1 its less stressful on the engine mechanically (detonation is a very violent and destructive force and takes its tool on rod bearings and pistons) and #2 it makes for an amazingly smooth car to drive. There is no bump in the power band or pulling of timing.
The concept is such a tune is quality not peak power - especially when dealing with 91 octane fuel.
I state as a FACT that ALL SAFC tuned cars are in a state of constant retarded timing through knock activity - (unless they are run on race gas only). This is not a good way to run a car.
There is no way to escape the reality of these facts.
Aditionally the SAFC is limited in that the ecu has two main maping settings, low and high octane. With the SAFC you are ALWAYS stick on the LOW octane map.
You cant properly set up a saftey measure for poor fuel with the 2nd map inside the ecu with SAFC
You cant take out the fuel cut or alter the rev limietre with a safc
You cant control bost with a safc either
in your signature you list figures which show significantly impaired TQ
While you can make good whp numbers with the SAFC and even get a decent track time in the narrow power band you drag race with the reality is that the car is dead below 5,000 with a SAFC tuned car and not a lot of fun to drive (compared to a properly reflashed car)
Al have you done any 20g tunes? I think i saw a post somewhere about one.Ive got someone already trying to buy the 20g from me if i decide not to use it and i havent even received it yet ! lol Im looking for real street driveability on 91 octane not just race gas. yea sure maybe id through some in for the strip but i want something i can drive around town not concerned where can i get that 100 octane at .. I havent heard of anyone else here in vegas running the 20g on their car - anyone running one? If you come out to vegas - count me in for a custom tune- id love to see peoples attitude change about them. I find it hard to believe that a safc could outdue a custom flash - or that you couldnt get better results with both working together properly . thanks lee
member Cremo03 on these forums had a 20 G tuned with a custom Dyno Flash road tune - the car was a animal on the road. His engine was 100% stock and he did not want to risk any damage so we limited his boost to 25 psi. There is more power on the table.
He made an easy 369 whp and 357 tq at the AMS dyno day.
The 20G is a great turbo
Seriously - you guys in Vegas should consider the alcohol injection kit.
First you can run a lot more boost and a more agressive tune with a total absense of knock
Secondly the alcohol dranatically lowers intake charge temps which is a huge advantage in the kind of heat you guys encounter
Originally Posted by vegasboy301
i see. give away a third spot al
currently 2nd fastest in vegas with a stock turbo
Additinally I note that if you look at the 107 case studies I have posted in my section of the forums you will see that an evo should make TQ at least equal to or greater than the whp
It is very hard to draw accurate generalizations about an entire product capabiliy based upon a hand full of individual experiences
Originally Posted by evolsk8r
So does this mean everyone is gonna back out of the tune this month and wait for a flash? I'd love to get flashed on a dyno, but don't have it in the budget right now since I just bought a house.
I hope not.
