Las Vegas Evo's
From: Where you come to vacation and go home on probation! Vegas!
Ok I got it running good. The only problem is when I first turn it on and do WOT pulls from say 1st or 2nd the alarm goes off and screen flashes orange/red but Im nowhere near the 21psi warning...... any ideas?
Originally Posted by M3this
Yea the plastic cap that you had out I put in ... should have known it was supose to be out
.. oh ... yea ... its in the step motor
I'm trying to get it to be at 19psi ... can I go 20psi on our crappy 91 ??? Right now Im peeking at 18.7-18.9ish with the current set up ...
If I bump up the Set Gain will it make the boost go higher? I think you had the set gain set at 15psi ... thats what I was going to move it up to according to the write up I read.
.. oh ... yea ... its in the step motorI'm trying to get it to be at 19psi ... can I go 20psi on our crappy 91 ??? Right now Im peeking at 18.7-18.9ish with the current set up ...
I forgot to tell you about that. It's a safety limiter in the controller. You have to push a button to get it out of the 14psi safety limiter. So I always toggled it from low boost to high and then back to low. This has to be done everytime you start the car.
this is the kinda **** we need to do! https://www.evolutionm.net/forums/sh...d.php?t=190745
