Las Vegas Evo's
Old Jun 16, 2008 | 12:59 PM
  #45811
bcampbell782's Avatar
Chris I saw you on Sat off of eastern and 215 I was at wendys as you were coming out of the chevron. My daughter has dance class where the coffee and cars things is and I thought I was too late for the little meet. Next weekend though.
Old Jun 16, 2008 | 01:42 PM
  #45812
wtmodnar's Avatar
Do we have any dyno days coming up? or do I have to go in individually =/. I just want to get a base dyno before I throw the mods and meth on for tune.
Old Jun 16, 2008 | 01:59 PM
  #45813
calilancer02's Avatar
I'll be going to tune in the next two week or so.. Soon as I get my lines made for injectioN.
Old Jun 16, 2008 | 04:37 PM
  #45814
wesside's Avatar
wtf lines made? You piece together a system?
Old Jun 16, 2008 | 05:53 PM
  #45815
brian250f's Avatar
Originally Posted by bzzbee2
Saw a quote in the RRE thread on socalevo... 600 for the tunes and switch. They recommend the 880 injectors (based on the mods that i currently have)
ive been looking into e85 a lot lately too.. chris, more info on the 2 maps. would i just have to run the tank to e (say on e95) then fill it up with 91 and flip a switch? well then i would have to turn the boost down and dial that in. it would be nice to have the 91 tune just in case.. oh and since i already have one of your amazing 91 tunes would it be cheaper, haha. let me know
Old Jun 16, 2008 | 06:19 PM
  #45816
wesside's Avatar
you can also have ecu controlled boost & when switching between maps switch boost levels at the same time Can even use that same setup with meth & no meth as well as having failsafe kick back boost n cut to different map...pretty cool stuff
I'm talking about the tephra v5 patch btw
Old Jun 16, 2008 | 06:51 PM
  #45817
bzzbee2's Avatar
I have read about all the cool stuff you could do with this tephra thingy... Its just a bit above my skill level at this time. Having the valet mode would be cool.
Old Jun 16, 2008 | 07:29 PM
  #45818
RC2099's Avatar
Anybody want there car done on Sunday? I have changed my off day to Sat b/c of some family events.
Will start as early as needed and so 2 hour blocks! Whos up?
Who all is going to be at CaC this Sat? I will be a little late but will be there!
Scott
Old Jun 16, 2008 | 08:23 PM
  #45819
wesside's Avatar
I've used the first patch for a long time now without the alt map switching.
I use Valet mode & Cel knock light
nlts (flat foot) mode --don't use
its really simple to do, I'm sure chris or someone down there would help you out if not I could help you out. Its modifying a few things then basically just copying all your maps over
Old Jun 17, 2008 | 09:37 AM
  #45820
20psiMR's Avatar
Im using his version 5 right now in my car, with Jacks harness. Thats what I was talking about. I also have knock light and ecu controlled boost, so map switching switches my boost back and forth from 25 to 20psi as well. But you guys are talking about getting into some serious ecu hacking. I have no prob doing it on my car because if I jack it up, its my bad and I fix it. Im just a little piddly garage tuner, I dont want to dive into the problems of doing stuff like that to be honest hehe. I did think about it.
For alt map switching, you would need to adjust boost as well, so like brian said its not just a flip of a switch since I know most of you are running MBC's.
Its complicated stuff, but if you guys want to dive into I could and have done it.
Old Jun 17, 2008 | 09:54 AM
  #45821
bzzbee2's Avatar
When i first heard about the Tephra thing i was researching ecu boost control with running the 2 maps. This was the path i wanted to take and still do, however i was a bit intimidated by it. I guess i just need start messing around with these things... Its not like im doing much at work anyway.. LOL
Old Jun 17, 2008 | 10:04 AM
  #45822
wesside's Avatar
Thats why I haven't got into ecu controlled boost yet because I've got a mbc and a mac valve for failsafe for my meth kit. So if I got into map switching I would just want a 91 octane map with same boost levels or just do like I currently have setup run outta meth etc.. failsafe kick in wastegate psi or turn off the spray and run wastegate...but wastegate psi sucks
now I'm not familiar with the ecu controlled boost since I haven't messed with it but everything else wasn't too bad just kind of a pain. I've also got my map 2byte & evoscan to read 2byte
peep
https://www.evolutionm.net/forums/sh...d.php?t=327185
I actually need to scale my tables out more still but well I just think it needs to hop back on a dyno after it gets put together again
Old Jun 17, 2008 | 12:53 PM
  #45823
Go_Lancer_Go's Avatar
Vegas evo owners... check my post pls
https://www.evolutionm.net/forums/sh...46#post5785246
hope 2 see u guys out there...
Old Jun 17, 2008 | 01:37 PM
  #45824
ohsobaked's Avatar
a dude i work in the same casino as(i barely know him) but anyways he asked me if i knew anybody that wanted to buy his 06 GG IX MR. It has 30,000 miles, fully stock with a brand new factory clutch. I told him to go to evom but then apparently he doesnt own a computer(wth doesnt own a computer nowadays?) so i thought id help him out and post it up. anyways i asked him how much he wanted for it and he said $28,000. i told him that 28,000 is ambitious. well if anyones interested or wants to throw an offer, pm me for his phone number.
Old Jun 17, 2008 | 03:51 PM
  #45825
brian250f's Avatar
thanks for all the info wes. i guess adjusting the boost manually wouldnt be so bad, i just want the 91 map in case i cant get any e85. i wouldnt mind having the valet mode tho. why do you say not to get the NLTS?
